Windows 7: No sound - help please!
03 Nov 2009   #11
Jonathan_King
Windows 7 Professional x64
Could you go to the driver tab and tell me what you see?
03 Nov 2009   #12
Stephen Pollard
These are from driver
03 Nov 2009   #13
Jonathan_King
Go into Device Manager and uninstall all drivers related to your sound card. Then reboot, and let Windows automatically install them.
03 Nov 2009   #14
chev65
Try this, set to DVD Quality. Usually clears up this type of problem.
03 Nov 2009   #15
Stephen Pollard
I'm afraid it hasn't made any difference.
I'm very grateful for the time you have spent on this.
03 Nov 2009   #16
Jonathan_King
Did you try Chev65's suggestion?
03 Nov 2009   #17
Stephen Pollard
Yup. Didn't work either.
I'm wondering if I should reinstall Windows 7 and see what happens? I won't lose anything as work is all backed up.
03 Nov 2009   #18
Jonathan_King
If you can, that might be a good idea. Let us know how it works out. Also, be sure to do a clean install, rather than an upgrade.
03 Nov 2009   #19
Stephen Pollard
will do
03 Nov 2009   #20
Jonathan_King
Did you do a clean install or upgrade from Vista?
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
