Windows 7: No sound - help please!
03 Nov 2009   #21
Stephen Pollard
A clean install
03 Nov 2009   #22
Jonathan_King
Windows 7 Professional x64
Okay, just wondering.
03 Nov 2009   #23
Snufffed
Since you will not fill in the SPECS, so we can see what Sony Vaio your using... What is the Model #.
when you open control panel --> open sound --> then open sounds.
make sure you have Windows Default checked.
move down an see if you can hear any of the MS default sounds, like startup or alerts .
If you move on the control panel --> system --> device manager
do you have any yellow markers or any RED markers.
04 Nov 2009   #24
Stephen Pollard
Well, I did a clean install and it's still silent. I've noticed though that there are none of the Windows default sounds. Yet Windows Default is listed as my sound option.
Any further ideas?
Stephen
04 Nov 2009   #25
Jonathan_King
Look, we really need your system specs. Please check out the link for instructions.
https://www.sevenforums.com/general-d...tem-specs.html
04 Nov 2009   #26
Stephen Pollard
Sorry to be so useless. I've talen this screenshot which I hope has the info. I can't work out what goes where in the system spec screen...
Stephen
04 Nov 2009   #27
Jonathan_King
This is a very strange case to me, and I know of no solution off the top of my head (as you can probably see). The best I can do is experiment and try different things. So, be patient with this, as I am learning too.
Go to this page, and download "Vista, Windows7 Driver(32/64 bits) Driver only (Executable file)". Do not run the file yet. Go into Device Management again and uninstall all audio drivers. Do not reboot the computer. Run the executable you just downloaded, and reboot as necessary. Let's see what happens.
04 Nov 2009   #28
Stephen Pollard
Hmmm. Well I tried that, and still no sound.
This is all very odd.
04 Nov 2009   #29
Jonathan_King
Do you have any headphones or speakers you can try?
04 Nov 2009   #30
axxo
Windows 7 Ultimate 32bit
Hallo! my motherboard is ASRock ALiveSATA2-GLAN and the sound card VIA VT8237A High Definition Audio Controller. i have installed windows 7 but have no sound. have installed many drivers but nothin, everytime says no audio output devices installed. is my soundcard compatible with windows 7 or is it an another problem? can someone help me please! thx
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
