Windows 7: No sound - help please!
04 Nov 2009   #31
Jonathan_King
Windows 7 Professional x64
Hello, axxo. Welcome to the forums! Could you please post you system specs?
https://www.sevenforums.com/general-d...tem-specs.html
04 Nov 2009   #32
axxo
Windows 7 Ultimate 32bit
hello Jonathan King! i have posted some system specs. all drivers are installed without a problem and the sound driver to, but there is no sound.
04 Nov 2009   #33
Jonathan_King
Please go back a few pages and review everything I told Stephen Pollard.
04 Nov 2009   #34
axxo
ok, here is the screenshot control panel -> sound. i hope it can help
04 Nov 2009   #35
Jonathan_King
Run msinfo32.exe and tell me what BIOS you have.
04 Nov 2009   #36
axxo
Bios version: American Megatrends Inc. P1.50
04 Nov 2009   #37
Jonathan_King
Okay, reboot you computer and enter the CMOS. This is usually by pressing F2 or Del during the POST. Navigate to the Advanced tab, and select "Chipset configuration". Confirm that any audio options are set to Enabled.
Caution: messing around in the CMOS is risky. Do not change values unless you know what you are doing.
04 Nov 2009   #38
axxo
I've done just as you said, all audio option are enable. in the device manager in the general tab i have this message: This device cannot start. (Code 10)
04 Nov 2009   #39
Jonathan_King
Click "Troubleshoot".
04 Nov 2009   #40
axxo
OK, and this writes there:
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
