Windows 7: No sound - help please!
03 Nov 2009   #1
Stephen Pollard
Hi. I've installed Windows 7 on my VAIO. All seems fine but when I try to watch anything on YouTube, or listen to the radio, it's silent.
The volume indicators say it's playing at full volume, but it isn't.
Anyone have any ideas what I need to do please?
Stephen
03 Nov 2009   #2
Jonathan_King
Windows 7 Professional x64
Let's just check the basics here: Is the speaker cable plugged in?
What sound card do you have? Can you please fill out you system specs?
03 Nov 2009   #3
ickymay
win7 ultimate / virtual box
have a look in control panel / sounds to see if you have the correct device enabled ?
03 Nov 2009   #4
Stephen Pollard
I don't have a speaker. I listen through the speakers on my notebook pc. All was fine with VISTA!
03 Nov 2009   #5
Jonathan_King
Could you please fill out your system specs?
03 Nov 2009   #6
Stephen Pollard
Sorry, I am something of a computer idiot. I have a Sony VAIO notebook, which used to be Vista and is now Windows 7. I'm afraid I have no idea how I find out all the various technical things asked for. I just turn it on, find what I want to watch, and press Play! Only now there is no sound.
03 Nov 2009   #7
Jonathan_King
Go into Control Panel>Sound and post a screenshot. Instructions for posting a screenshot can be found here.
03 Nov 2009   #8
Stephen Pollard
here it is...hope it helps.
03 Nov 2009   #9
Jonathan_King
Now what happens is you click on the speakers and hit Properties? Please post a screenshot.
03 Nov 2009   #10
Stephen Pollard
Thanks for bearing with my ignorance!
Here are two more pics
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
