Creative X-Fi Xtreme Audio plays no sound
  1. Posts : 7
    I installed my soundcard, everything works perfect. I installed drivers and i get no trouble at device manager. After I plug my headphones in and try to play music, i get no sound. At the sound options in windows i see the soundcard and it looks like it works, because the green bar goes up and down. I read that i need to turn onboard sound off in bios. I couldnt find it in my bios (Award Software F4), dont know why, so i deactivate onboard sound at device manager but it didnt work. Maybe someone knows the problem and can help me :)
    Best regards,
    erDi
    Windows 7 Ultimate 64bit
    If you have installed a separate sound card, the front panel headphone jack connection has to be moved from the motherboard to the separate sound card. If you didn't move the connection that is probably your problem.
    Depending on the age of the PC and the BIOS, the on-board sound could be labeled "Legacy Audio" in the BIOS.
  3. Posts : 7
    Thank you for the help. I opened my computer and saw that there is a cable at the soundcard which isn't fitted. There are letters on it: AC 97 (http://ask.creative.com/wwimages/aud...ontpanel2a.jpg). Did I understand you correct and have to connect this cable to the mainboard?
  4. Posts : 8,135
    The HD Audio is the preferred connection as it has jack sensing that the AC97 does not have.
    The cable must be connected to the SoundBlaster sound card to have front panel headphone audio from the SoundBlaster.
  5. Posts : 7
    Ah now i understand, but that can't be the problem, because the front panel headphone jack connection has already been moved from the motherboard to the separate sound card.
  6. Posts : 8,135
    Has the front panel headphone jack ever worked? Try the AC97 connector and see if works with that.
    Does the PC speakers work with the SoundBlaster? Try plugging the headphone directly into the Speaker jack on the SoundBlaster and see if the headphones work.
  7. Posts : 7
    I'll do it tomorrow and give my experience. Thanks
  8. Posts : 7
    The front panel headphone jack just works with Onboard sound. The AC 97 connector doesn't work, Soundblaster doesn't work with speakers...
  9. Posts : 7
    System control -> hardware and sound -> sound -> right click SB X-Fi Xtreme audio -> properties ->connector information -> no connector informations available
    Is that normal?
  10. Posts : 8,135
    Sounds like the SoundBlaster requires a custom front panel connector. I ran into that with Dell's that used one model Xfi sound card.
    Is the Xfi fully Windows 7 compatible? I remember issues with some model Xfi cards not being supported by Creative for Windows 7.
