No Audio Output Devices is Installed- Sony Vaio
  1. Posts : 6
    Window 7 Home Premium 64 Bit
    I have a bluetooth headset that already paired but it is unable to use because there is no audio services to work with. When I run the troubleshooting for my sound, it couldn't identify the problem. In my device manager, the bluetooth audio is gone (it used to be there) and i also have many unknow device that related to bluetooth. I used to played with registry when i was trying to fix something else, maybe that the cause, but when i run the Sfc /scannow, notthing seems wrong. I have been searching solution for this problem for a month and yet, notthing works. Please help, im using sony vaio Model # SVS15116FXB. I also tried to download some drivers from the sony sites, but they are useless.
    Attached Thumbnails Attached Thumbnails No Audio Output Devices is Installed- Sony Vaio-sound.png   No Audio Output Devices is Installed- Sony Vaio-device-manager.png
    I would uninstall all the unknown and Bluetooth devices listed in the Device Manager. Leave that off until you get the basic sound going again. Restart the PC after uninstalling all the Bluetooth and unknown devices.
    If the PC's sound device is enabled in the BIOS, Windows should detect it and install either the regular drivers or at least the generic, basic function, HIgh Definition Audio Drivers (Codec). If its not being detected and installed, the first thing is to check the BIOS. If its disabled in the BIOS then Windows will not see/detect it. If its enabled in the BIOS, reinstall the Intel motherboard chipset drivers. One of the things the chipset drivers do is define (identify) all the devices on the motherboard. This too affects whether the sound can be detected.
  3. Posts : 18,415
    windows 7 home 64bit
    In addition to the excellent Advice above ... Select each of the unknown Devices right click select Property's / Details Tab ..Please post the Hardware ID ....
  4. Posts : 6
    Hi, thanks for reply
    i tried to uninstall the unknown driver but when i started window up again, its the same problem. My sound device is enabled in the BIOS. Can you give me the link where i can reinstall the Intel motherboard chipset drivers?, ty
  5. Posts : 6
    Hi,thanks for reply, these are unknown devices hardware ids, I tried to uninstall and reinstall it but the problem remain the same. And I cant update the driver for some reason, idk why.
    Attached Thumbnails Attached Thumbnails No Audio Output Devices is Installed- Sony Vaio-unknown-device.png   No Audio Output Devices is Installed- Sony Vaio-unknown-device-1.png   No Audio Output Devices is Installed- Sony Vaio-unknown-device-2.png
  6. Posts : 8,135
    If the Sony downloads for your PC do not list one, Go to www.intel.com Use the Intel detection program to scan your PC. It will (should) list the available chipset driver.
  7. Posts : 18,415
    Below is the Chipset Driver you need ....
    Sony eSupport - SVS15116FXB - Drivers & Software
  8. Posts : 6
    I tried the drivers from both site but the problem remain the same ...
  9. Posts : 18,415
    Did the Driver not Install ? ....
  10. Posts : 8,135
    Although a "last resort" and I don't like to suggest it, a reinstall may be in store given the problems and what "won't install".
