ONE of the worst problems ever....:( help guys
  1. Posts : 21
    windows 7 32 bit
    i installed windows 7 32 bit and i have a ati hd radeon 3870 right, but there is no sound ive inserted my drivers cd, ive gone onto asrocks drivers site ive went on guru 3d ive tried everywhere, when i go on sounds it says VIA is working but it fails tests and the ati hdmi output is not plugged in...i have no sound?
    ive tried the realtek website etc
  2. Posts : 5,747
    7600.20510 x86
    In device manager, if it shows under sound section that "ATI High Definition Audio Device" is not working well after a successful video card driver installation, you should update your motherboard bios. Also, disable any unused ports such as serial and/or parallel in the bios after update. (Or now if no update.)
    Also install audio driver for you board.
    http://www.asrock.com/mb/download.as...l=N68-S&o=Win7
    Right click the speaker icon near the time in system tray. Choose playback devices. You can right click in there and set to show hidden devices.
    Right click on the one you want and choose to set it as default device.
  3. Posts : 21
    windows 7 32 bit
    ive done that not worked thanx alot anyway pal........do you think i should buy separate sound card?
  4. Posts : 5,747
    7600.20510 x86
    You did a bios update already? No, if you follow my instructions carefully, your system will be well as is.
  5. Posts : 21
    windows 7 32 bit
    yeah i meant ive already updated it long time ago it is the latest one,
  6. Jaq
    Windows 7 Professional 64 Bit
    Apparently others with your motherboard are having the same problem - try a search, there might be a solution.
    I will look and report back if I find anything.
    New drivers releaed 2nd November get them here:
    http://www.realtek.com.tw/downloads/...&GetDown=false
  7. Posts : 21
    windows 7 32 bit
    thanx mate ill try them drivers now will they work with my ati card?
