Audio dropouts/Pops
  1. Posts : 9
    Audio dropouts/Pops
    This has been an issue on both my old/new PC, I cant ever figure out how to fix this but it's been driving me mad. It randomly just gets worse at the worst times. I ran LatencyMon for a few minutes and got this: Audio pops - Pastebin.com
    This latency issue has been going on since my old PC, my current one is only less than a month old and its been doing it to. Lots of audio pops and dropouts.
    A lot of the main ones I see come up are:
    hal.dll
    ataport.sys
    ndis.sys
    USBPORT.sys (Fixed by disabling USB3.0 apparently)
    NETIO.sys
    iusb3xhc.sys
    You list the sound card as AMD High Definition Audio Device, which is sound for HDMI, not the regular PC sound. Are you using HDMI?
    The regular PC sound would be RealTek, IDT, etc.
    Are you using Wi-Fi or wired cable for internet? Wi-Fi is a known cause of your problem.
  3. Posts : 9
    I have Realtek then.
    I have a wired connection too.
  4. Posts : 8,135
    Do you have the Gigabyte Easytune installed? That is known to cause the problem you have.
  5. Posts : 9
    Nope
  6. Posts : 8,135
    The iusb3xhc.sys comes up quite a bit when doing google searches for your problem. From what I can find it has something to do with the USB3.0.
  7. Posts : 9
    Yea I figured it was so I went into BIOS and disabled 3.0 and move all my stuff to 2.0, but it didnt seem to change anything.
  8. Posts : 8,135
    I have USB 3.0 and do not have the problems, so it may not be USB 3.0 but some driver. I use my PC for my recording studio so Latency, noises, etc are very important. My system is clean with the Latency Mon. I was using a Gigabyte GAZ77X UD5H motherboard but it developed problems and I've switched to an ASRock Z77 motherboard - both have USB3.0.
    As your old PC and new one have the same problem, what is common (same) with the two? Hardware or software.
    BTW, here is he way to post screenshots on this forum.
  9. Posts : 9
    Well hardware-wise, the only things that are the same are 2 HDD's that I took from my old PC to my new one. My old one was an older version of the stock Dell Inspiron 620 with an added graphics card and HDD were the only 2 aftermarket items. Software, very similar, same antivirus, same PC diagnostics and cleaning software, same games, same browser...etc.
  10. Posts : 8,135
    Considering you are using the old hard drives from the Dell system, did you do a complete "clean" install on the new system? (Clean install - reformat the hard drive and install Windows, drivers, software). If you didn't do a clean install the problems you had could very well still be there.
