Sound quality crackle
  1. Posts : 12
    windows 7 32bit
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    did you want me to install this or just upload it for you?
  2. Posts : 6
    Windows 7 32bit
       #12
    I unchecked the software and rebooted, and it worked for about 2 minutes, before the crackling resumed
  3. Posts : 5,747
    7600.20510 x86
    You could try to install, but if it doesn't (probably won't) - I'll work on it to make it so. I am at another machine right now so it will not be too long....but a little.
  4. Posts : 5,747
    7600.20510 x86
       #14
    I told you the wrong driver before. It was for x64 but I couldn't tell from that page. And I had ZA set to block Microsoft services. I figured that out and got the right driver, then modified.
    Anyhow...
    Download from this link and use Winrar or similar to extract to C:\AudioDriver
    In device manager, right click on the audio device. Update driver software. Browse my computer for driver software. Let me pick from a list of device drivers on my computer. Click the Have disk box. Click the Browse box. Then navigate to C:\AudioDriver and click (or double click) on HDA861A.inf
    Hit ok and let it finish installing.
    It should definitely install, but I don't know if it is actually going to fix the problem. So, good luck. Let us know how it goes.
  5. Posts : 6
    Windows 7 32bit
       #15
    It made it worse
  6. Posts : 12
    windows 7 32bit
       #16
    yeah same
  7. Posts : 12
    windows 7 32bit
       #17
    did you uninstall the previous driver?
    cause i hink i did but for some reason everytime i uninstall then resart the computer whiloe its loading my computer is automatically installing a driver for the audio
    and i cant sem i find whats doing this
    i dont think this matters tbh
  8. Posts : 6
    Windows 7 32bit
       #18
    I'm not sure, but probably not. I've reverted to the latest driver, because it gives me the best audio, and i cant live without dvds or music lol
  9. Posts : 12
    windows 7 32bit
       #19
    hey man i found a driver seems to be working
    i used a driver robot thingy and managed to find the driver for it seems to be fine atm
    give it a go Driver Robot: Guaranteed automatic driver updates
    click on the audio one not the other
    good luck
  10. Posts : 12
    windows 7 32bit
       #20
    ahhh k nevermind ill tell you how i did it
    i downloaded driverrobot ran a scan
    then after the scan dont register or whatever it comes up with just cancel it
    then click exporter and it saves a file in documents ot wherever you want
    then just click on that file takes you to a web page then click get drivers and there should be the driver one there for you
    it went ok for me and no problems with audio but is a tad quiet (but was like that anyway before the crackle, probly just my laptop :) )
    hope it works for ya
