RapidShare: 1-CLICK Web hosting - Easy Filehosting
did you want me to install this or just upload it for you?
I unchecked the software and rebooted, and it worked for about 2 minutes, before the crackling resumed
I told you the wrong driver before. It was for x64 but I couldn't tell from that page. And I had ZA set to block Microsoft services. I figured that out and got the right driver, then modified.
Anyhow...
Download from this link and use Winrar or similar to extract to C:\AudioDriver
In device manager, right click on the audio device. Update driver software. Browse my computer for driver software. Let me pick from a list of device drivers on my computer. Click the Have disk box. Click the Browse box. Then navigate to C:\AudioDriver and click (or double click) on HDA861A.inf
Hit ok and let it finish installing.
It should definitely install, but I don't know if it is actually going to fix the problem. So, good luck. Let us know how it goes.
It made it worse
did you uninstall the previous driver?
cause i hink i did but for some reason everytime i uninstall then resart the computer whiloe its loading my computer is automatically installing a driver for the audio
and i cant sem i find whats doing this
i dont think this matters tbh
I'm not sure, but probably not. I've reverted to the latest driver, because it gives me the best audio, and i cant live without dvds or music lol
hey man i found a driver seems to be working
i used a driver robot thingy and managed to find the driver for it seems to be fine atm
give it a go Driver Robot: Guaranteed automatic driver updates
click on the audio one not the other
good luck
ahhh k nevermind ill tell you how i did it
i downloaded driverrobot ran a scan
then after the scan dont register or whatever it comes up with just cancel it
then click exporter and it saves a file in documents ot wherever you want
then just click on that file takes you to a web page then click get drivers and there should be the driver one there for you
it went ok for me and no problems with audio but is a tad quiet (but was like that anyway before the crackle, probly just my laptop :) )
hope it works for ya
