Sound quality crackle
Page 4 of 5 FirstFirst ... 2345 LastLast
  1.    #31
    Hey I updated my Bios it was weird my computer shut down like the last time it was bricked. Except this time the computer started up normally and i checked and my bios is up to date. Still have sound problems but in addition to sound crackling it doesnt recognize my external speakers i just think its the fact that theres no windows 7 drivers for HP. The windows vista drivers dont work when i try installing the Conexant High-Definition Audio Driver it says "ERROR: could not find the media device for the specified driver" something along those lines, lol.
  2. Posts : 5,747
    7600.20510 x86
       #32
    Go to device manager. Right click on your sound device. Properties. Details tab. Change dropdown to hardware ids. Copy and paste the results here.
    I'll either find the latest Win7 driver for you or make you one that's meant for another system, that will work.
    I can't say it will fix the problem, but at least you'll be using latest driver in any case, doing this.
    HDAUDIO\FUNC_01&VEN_14F1&DEV_5047&SUBSYS_103C30B2&REV_1000
    and
    Thanks a lot in advanced, I really appreciate it!
  4. Posts : 5,747
    7600.20510 x86
       #34
    and
    In Internet Explorer only, go to this link.
    The second and third ones down are the drivers. One is for x64 and the other is for x86. You'll have to see when downloading which is which. Get the other one if it's wrong.
    Then install using device manager. Let us know how it goes.
    It made my external speakers sound BEAUTIFUL again! But it made my on board laptop speakers sound a lot worse. But really thanks now i can watch hulu and listen to music and edit films/docs with great quality on my external speakers. Also it fixed the mute problem i had too that i forgot to mention haha! Thanks again.
  6. zel
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0660&SUBSYS_10430000&REV_1000
    same problem can you help me to?
    you don't need to take action on this one,i resolved this with driver robot.
  7. Posts : 10
    windows 7
       #37
    Advent 9115 windows 7 Audio driver
    If anyone requires the correct audio driver for the advent 9115 . I will Post a link up for it cheers kev
  8. Posts : 2
    windows 7
       #38
    If anyone requires the correct audio driver for the advent 9115 go to this link http://support.pcworld.co.uk} it works fine on my laptop i know it says for windows vista but it works fine with windows 7
  9. Posts : 9
    w7
       #39
    i have the same problem, is there any information or files or drivers you need for me to help ? to me it just seems the windows 7 drivers for this laptop dont exist , (the advent 5302)
  10. Posts : 3
    Windows 7 ultimate x64
       #40
    I have the same cracking noise on my advent 9115.
    OS: Win 7 x86
    Is there anyone still have the proper driver and could upload it as I can't find anywhere on the internet.
    Thanks in advance.
