No sound through earplugs, although plugging in is recognized
  1. Posts : 6
    Hi all,
    I have a curious problem, which I'm not able to solve on my own although I've a couple of solutions. Here is the problem:
    When I plug my earphones in, its recognized that something is plugged in, the sound output changes, but I hear nothing through my earplugs.
    I'm sure that: the hardware is working correctly (I have a dual OS system, and there everything is working fine). I have already reinstalled the drivers, reinstalled the HD Audio manager from Realtek including their drivers. One time, I had it working, but with the next reboot it did not work anymore.
    In my sound settings everything seems OK, at least when it was working the same devices were listed and asssigned as standard devices so I dont think that the problem lies there. Anybody has an idea what to do or how to solve this?
  2. Posts : 21,004
    Hello and welcome Wonkie mate seems rather an obvious question but do these ear buds work in anything else??
  3. Posts : 6
    Yes, I've also tested with different sets of earplugs..
  4. Posts : 21,004
    Ok mate look some system specs would be helpful here as it sounds (no pun) like a driver problem or maybe - worse though - a socket problem.
    System Info - See Your System Specs
    Even the model of the laptop would be good as if we do not know what you have it makes it so hard to pi things down to the detailed stuff inside the machine.:)
  5. Posts : 6
    Sorry for the late reply. I'm also studying and it can be sometimes quite demanding to do everything at the same time. I uploaded the info to my profile, if anything else is needed, please let me know.
    There is some interesting outcome in the summary provided by the executable you gave me, there are three sound cards listed:
    1. Nvidia
    2. Realtek
    3. Intel
    The Nvidia card is listed first, could this have anything to do with the problems I am experiencing?
  6. Posts : 21,004
    Hmm now you have my curiosity fired up as I can understand the Intel and Realtek as sound sources but the NVidia has me wondering what it is? The only reference I can find is to one that is an APU which used to be associated with AMD CPU's has recently been taken up by Intel.
    In other words the CPU carries a graphical and sound component. I really don't know which of these are being used on your machine.
    Now there are some references to the NVidia sound component and I am not real sure now of what to do.
    I think it might be an idea to run HW Info see my ditty and pic to see what is actually on the system.
    Using HW Info
    You can test the volts on the PSU with HW Info HWiNFO, HWiNFO32/64 - Download < download the right bit version and close the right hand window select Sensors and scroll down to the power section where you will see what the volts are doing see my pic.
    The original right hand window shows the machine running and is handy for that but for looking at the components in some detail close it and use the main left hand side panel
    FOR OTHER COMPONENTS
    Open each + down into the component itself and then click on it - in the right hand side will appear all sorts of details including brands speeds and other essential info that device. See my pic for an example.
    Just use the latter part.
    Attached Thumbnails Attached Thumbnails No sound through earplugs, although plugging in is recognized-hw-info-audio.png
  7. Posts : 6
    Hi ICIT2LOL,
    I'm not quite sure what you're expecting from me, but here is some info on the Audio device. The Nvidia audio device probably comes from the HDMI connection which is on this card, and of course also includes sound. I think its not related to my problem.
    I need to say again, that the earphones are working proper in my other OS (as I have a dual OS system) which is Arch Linux. There pluggin in and out results in the desired outcome. So I'm not sure whether this a hardware problem, I thinking more about a software problem.
  8. Posts : 21,004
    Hmm well as you say it does seem to be a software problem and it also seems to me that while in Linux the drivers are fine but not in Windows?
    So I was thinking that you may need to reinstall that driver for that device you posted while in Windows.
    The drivers for the Cougar Point I cannot find on the Intel site and as you say you have installed the driver from the Realtek site maybe trying them form the Asus site could prove to be a fix I am not sure but worth a try
    http://www.asus.com/Notebooks_Ultrabooks/K53SV/HelpDesk_Download/
    I don’t know if it would help either if you ran these too
    https://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
    https://www.sevenforums.com/tutorials/433-disk-check.html < if necessary include the /f and /r in the command line as per Option2 (in Windows boot of course)
  9. Posts : 6
    Thank you so much for your help ICIT2LOL! I reinstalled the original driver of which you provided the weblink and now its working again.
    Again, thanks for your support and suggestions!
  10. Posts : 21,004
    Good it worked mate and if you feel like a little more out of your machine run through this tutorial
    Optimize Windows 7 there are a few tweaks that are registry based one and I know Brink is the master and really is the master when it comes to jus about anything bit I always back up the registry for two reasons -
    a) when ever I do a clean install or
    b) when tweaking the registry and like I said there are no problems with what Brink instructs you to do - more that I do it because I may or someone else might hit a wrong key and then it is only a matter of merging the full registry back again. F course you do not have to use the tutorial but I think you will notice a considerable improvement in the performance of your machine.
    To backup the registry - Registry - Backup and Restore takes about a minute and a half to do and saves you form wrecking the machine:)
