#21
The problem came back again after a restart, so I uninstalled all the Dell programs and once again, all is good. Fingers crossed that it holds this time!
I too just obtained this account to thank you. You saved me days. Is someone in touch with Dell? If not, I could start a campaign.
Very Best,
Michael
Just adding another confirmation of the problem and the solution (thanks!). I have a Dell XPS L502X Windows 7 Home Premium laptop. In the last couple of days, all audio recording and playback exhibited the stutter and drop-outs reported above. Dell SupportAssist and Dell SupportAssistAgent were automatically installed on my machine February 10 and 12 (2015), respectively. Uninstalling those programs removed the culprit system device Dell Diag Control Device (file DDDriver64Dcsa.sys - the file itself actually remains) (also removes system device Dell System Analyzer Control Device). I see today many people are reporting the same problem and solution on the Dell Support Forum (Laptop Audio Forum).
I called the Dell 817- support number to try to report the problem, in hopes they will acknowledge it and not simply reintroduce the defective software to machine again. You can imagine how productive that conversation was.
Registered just to say Thanks!
Dell is Trash. DDDriver.sys also disabled keys 's,x,caps lock' on my keyboard.
Disabled in Device manager. Keyboard is now fully functional and most important the stutter is gone.
THANKS AGAIN!!!
Registered entirely just to say THANK YOU and also WTF? I was honestly just about to give up and start looking for a new laptop. I work with audio and this has been making it impossible to get any work done. Thank you so much.
I have exactly the same laptop model and issues. and disabling 'Dell System Analyzer Control Device' worked for me too.
Also, uninstalling Dell Assistant-something (can't remember what its called now) removed the driver. For anyone with the know-how to get this far, it's probably a useless program anyway.
I suspect a recent Windows 7 update is responsible for issue.
We're all gonna make it. :)
It started again for me after a couple of days of rest disabling the Dell Diag Driver! I tried to disable the other Dell driver, but no improvement this time. Hoping for some pros to find the root cause and solution.
Thank you, kind souls. My Dell Inspiron started doing this I think after the last system update. I followed your instructions and voila! It is fixed. I also registered specifically so I could post that you fixed my dilemma also.
