Front audio panel panning issue. Both sides playing at the same time.
Both my front audio ports detect devices I plug in. The issue is, both sides play at the same time even if the panning options are set to the middle to play both right and left. If I pan all the way to the right and test the right speaker for sound, it would result in both sides playing. Testing left would mute both naturally. Panning all the way to the left does the same thing. Plays both sides, if the left speaker is tested and naturally would mute both if the right is tested.
Microphones work with no problems and other devices are still being detected aside from the panning problem. All other headset experience the same panning issue including phone headsets.
I have installed the latest Realtek drivers, the back panel is working perfectly but my wired headset isn't that long which is why I'd prefer to use the front audio panels.
Motherboard: MSI Z87 MPOWER (Not the max one)
Case: Antec Three Hundred Two
