Windows 7: Crackling sound and audiodg.exe problems
09 May 2010   #41
Aphelion
Windows 7 Home Premium
Quote   Quote: Originally Posted by Shintsu View Post
I registered as I found this problem mentioned here is the one I'm encountering. I however have NONE of the things you people have and I still have this problem. It just did it a little while ago for a full minute when I was watching a flash video and then it wouldn't come out.
Two things... 1. make sure your motherboard has the latest BIOS running.
and 2. Avast has a realtime scanning function... this has been known to cause similar probelems.
Try rebooting, let the machine settle a couple of minutes, then open Task Manger and go to the "Processes" tab make sure the "show all processes" checkbox is enabled. Next, make a screen grab of only the Task Manager and post it here.
Ap
10 May 2010   #42
Shintsu
Windows 7 Professional 64-bit
Quote   Quote: Originally Posted by Aphelion View Post
Ap
If the BIOS has an effect on this, I have never updated it. Always was paranoid I'd do it and screw my mobo up - so being my mobo is EVGA do I get the updated BIOS from them? Or is this provided by something else like Biostar or something? I've never actually done a BIOS Flash before so a bit clueless on how exactly that works.
Here's the pic of my Task Manager (Large pic - one thing got clipped it was Xfire64.exe). Also, there was no check box but a button that said to show All User Processes which I clicked.
Uploaded with ImageShack.us
EDIT: I just looked on EVGA's site and I see that all I need to do to flash it is burn the .ISO of it to a CD and then boot off it - is any input from me required at all? It mentions clearing CMOS by powering down afterwards, is this anything more than just shutting it off - like do I need to do something like remove that CMOS battery or unplug it or anything like that?
10 May 2010   #43
Aphelion
If you haven't done a BIOS update before or are the least bit unsure I'd hold off until you gathered more info. The Hardware & Devices forum might be a good place to ask for advice. A BIOS update has helped some as they tweak the timings and other non-user settings to be more compatible with newer operating systems & processors.
Ap
12 Aug 2010   #44
d1kk3
Win7 home premium 64 bits
I just wanted to put this in here cause i have been experiencing severe crackling,popping audio too.
Since i see alot of people fixing it with A bios update and im always up to date with my bios....,i decided to downgrade my bios and guess what!!!!!????
All my problems with creative x-fi cracking and popping is gone!!!!!
If u still experiencing all of the above named problems try a bios Upgrade and if u have latest version like i had try a bios downgrade!!!!
For me it fixed it all!!
My Mobo is btw Asus P6T (X58 chipset) and current working bios without the craclking noise is version 1201
Good luck.
22 Aug 2010   #45
RISOMMER
Windows 7 64 bit
I had the same problem on my laptop using Windows 7 64bit.
Got now from Microsoft a special hotfix which solved the problem: KB 981013
You have to ask for the download, special versions for each Windows version available,
but most important: It seems they had success....
25 Aug 2010   #46
DarrylGittins
Rats! That sounded promising, so I installed the hotfix but it didn't resolve the issue on my system.
Thanks for posting, though!
24 Sep 2010   #47
ffetchers
windows 7 pro 32-bit
Crazy fix!
I had all the popping myself, tried all the fixes, nothing has worked yet (Logitech USB headset).
I was looking at the Properties for Playback Devices (Sound dialog box popped up). Clicked on the Playback tab, manipulated things, turned Enhancements off, changed volume, etc, etc...
So while I was listening to the crackling and watching the little led lights going up and down I decided to click on the "Recording" tab--and the crackle was gone completely. So just for fun I clicked back on to the Playback tab and the crackle came back, so I clicked Recording and it was gone.
I then closed the Sound dialog box and the crackle came back; I opened it again and went back to the Recording tab and it went away. What the heck?!
So now I have the sound dialog box opened in the background, with the Recording tab showing. all my stuff sounds fine.
No wonder so many people are moving to apple
08 Oct 2010   #48
DarrylGittins
Good luck getting this resolved. I gave up on my system after replacing every component including the motherboard and Power Supply. So I foolishly went out and bought a new computer. An HP HPE-150f running Windows 7 x64. Guess what? Exactly the same problem. The only common factor is Windows 7 x64. The only workaround is to reboot the computer several times a day.
08 Oct 2010   #49
Aphelion
Quote   Quote: Originally Posted by ffetchers View Post
So, what is the default recording device?
Change the default recording device.
Ap
01 Nov 2010   #50
Chiser99
I had the same problem and after reading through this thread I downloaded the DPC latency checker and went through enabling/disabling devices in device manager to identify the culprit.
For me, it turned out to be my realtek ethenet controller. Interestingly, the DPC spikes only came back once it had reconnected to the internet, not immediately after re-enabling the controller. I realised I was downloading in the background, and after disabling the download the spikes went away, so it only seems to happen when actively transferring data using the controller.
Updated to the latest version of the drivers, but alas no fix. Just keep the internet traffic to a minimum while listening to music for now I guess.
Sound Doesn't Work After Ended Process of Audiodg.exe
After ended process tree of audiodg.exe using Resource Monitor,my volume doesn't work. How to make my volume back to normal? Help me please.
General Discussion
Crackling sound problems on Packard Bell MH35 (Hera C)
Hi all, been having a few issues with this laptop I recently purchased. I am getting slight crackling/pop noises from the built in speakers when playing sound. I have also tried two different sets of speakers and external ones which also result in crackling. On device manager the audio device is...
Sound not working since deleting audiodg.exe
I've just about come to my wit's end with this problem, I already have spent hours trying to fix it with no luck. A few months ago this 'Windows Audio Device Graph Isolation' a.k.a. audiodg.exe process program somehow got onto my computer and has since been playing random sound effects at very...
Genius Sound Maker Value 5.1 Crackling Sound
Hello, I upgraded my Win XP to Win 7 like 1 month ago. Downloaded all drivers (from their sites) updated them... then i open WMP 11 and start playing some music. After listening to that i heard some weird sound lag, I believe its called crackling. I searched on internet found some solutions, but...
[Sound crackling ] VPN client messed up my sound settings
Hi folks, Recently I was setting up a VPN client (PacketIX), and the setup wizard suggested some Audio/Video Streaming "Optimization" tweaks. I didn't pay attention and confirmed. Since then, I often hear some crackling / popping noises. For instance, this systematically occurs when I...
