Realtek drivers no sound present
  1. Posts : 13
    Winows 7
    Anyone please help
  2. Posts : 13
    Winows 7
       #12
    Help
  3. Posts : 299
    openSUSE 13.1 64bit
    I've had major issues with realtek and my new build with W7, and not getting any sound.
    Heres how I fixed it.
    • In device manager, uninstall all audio devices.
    • reboot the pc (it may load default windows audio drivers) don't expect any sound you have removed the audio devices.
    • Download and install the latest real tek drivers from your motherboards website..NOT from realtek.
    • Once installed, reboot the pc- it will prompt you to do this any way.
    • Don't expect sound yet
    • Go to controll pannel and click on the green hardware and sound header, not the list under it.
    • Realtek should now be in the list
    • Select the required speakers (in my case, High Def Audio device, I also use the single green jack on the back of the PC)
    • You should now have sound, I did.
    Hope this helps.
  4. Posts : 9,582
    Windows 8.1 Pro RTM x64
       #14
    Your motherboard does indeed have the Realtek audio codec (ALC888). You can get the latest driver direct from Realtek. See the following links for details of the latest driver, my recommended installation method, and the main support page for your motherboard (for reference).
    Latest Realtek HD Audio Driver Version
    Device Manager - Install Driver - Vista Forums
    ASRock > Products > ALiveSATA2-GLAN
  5. Posts : 13
    Winows 7
       #15
    thanks a lot,i'll try and get back to you.
  6. Posts : 13
    Winows 7
       #16
    Sorry still nothing after i didi everything,any more ideas,i simply don't have realtek after instalation
  7. Posts : 48
    Windows 7 Build 7600 64 bit
       #17
    Try this...
    1-Install the latest HD driver from realtek
    2-Plug ur cabel to subwoofer
    3-Tick and subwoofer when pop-up is on screen_(if not show)(Control panel,Audo,Sound Effect manager,)
    4-Try play a music
    i have this problem to..by do this its working but..when play a game do not have any sound..I reinstall the windows still same..i install windows vista sp 1 and install windows 7 7600 X64 and its working...
    Good luck
    Have a nice day..
  8. Posts : 13
    Winows 7
       #18
    Thx i'll try.
  9. Posts : 13
    Winows 7
       #19
    Nothing people,is it easier to buy sound card then to do this? I think so
  10. Posts : 48
       #20
    i think do not have to do that becoz is ur comfirm that ur sound plug is damage>>??or buy a new MOBO la
