Laptop Sound Very Low
  1. Posts : 657
    Windows 10 Pro
    Sager NP2740 Laptop. The sound is very low on my laptop even when i have volume turned on 100%. Many times on youtube as well the sound is very low when its at 100 percent. A while back it was not like this.
    Can someone tell me whats the reason for this?
    Please fill in the My System Specs" so we know what hardware you have.
    For example, what sound chip (card) do you have? and have you installed the latest driver or if you have the latest driver have you tried reinstalling it?
    If you only have the generic, basic function, Windows installed High Definition Audio Driver (Codec) install the correct sound driver.
  3. Posts : 169
    I was wanting to check out the OEM's associated with this laptop and Googled for a manual. DO NOT click on these links if you are wanting to get the Manual for the Sager NP2740: [REMOVED] and [REMOVED] They come with a Trojan/virus!
    Last edited by derekimo; 15 Apr 2015 at 18:34. Reason: Removed questionable links. Don't post infected links!
  4. Posts : 657
    Windows 10 Pro
    Can someone explain the last reply?
    Sound still very very low.
