"Device in Use" No Sound From Speakers.
  1. Posts : 26
    Windows 7 Professional 32bit
    i played an Audio File But No Sound coming From Speakers , i test the Speaker , but everyTime i test the Speaker i Get " Device in USE " Error. Some One help me to Fix This.
    My Windows and All Drivers are Up-to-date. (IDT High Definition Audio).
    I tried every available solution on Google but No help.
    Someone help me to identify which service/ program etc conflicting with my Audio Driver and causing This Issue...
    Please Reply Soon.
    Thanks in Advance...
  2. Posts : 26
    AnyOne ????
  3. Posts : 8,135
    What programs, that may use audio, do you have running? What is in the Notification area (lower right) such as Skype, etc?
  4. Posts : 26
    Their is No Program Running which is Using Audio .... But Sometime it Works Fine ( and i run VLC , Skype and Games at the same Time , no Issue). But Sometimes Not a Single Program Works and i get Device in Use issue...
  5. Posts : 8,135
    Recycle the sound device. If there are any Windows corruptions this will fix it.
    Go to the Device Manager, RIGHT click on the IDT sound entry and then LEFT click "Uninstall". DO NOT uninstall the driver. Restart the PC and when Windows starts it will detect and reinstall the IDT sound.
  6. Posts : 26
    Tried , and it Fix the Sound Temporary , again after some restarts Same issue ...
  7. Posts : 8,135
    Look at the Task Manager, may find the program that is causing it listed.
    Example:
    Attached Thumbnails Attached Thumbnails "Device in Use" No Sound From Speakers.-capture.jpg
  8. Posts : 1
    Windows 7 Enterprise
    This solution worked for me.
    I have had this problem on a Dell Latitude, and I finally found a solution that worked for me. In the Control Panel, in Hardware and Sound, there is an IDT Audio Control Panel. In that panel, I unchecked "Enable Power Management." I rebooted and the problem disappeared and has not returned.
  9. Posts : 1
    Windows 7 w/ XP VM
    Thank you VERY much for posting this! Your fix has resolved quite a frustrating ongoing random issue for us. Thank you!
