Realtek problem
  1. Posts : 5
    Realtek problem
    Ok, so I just installed windows 7 and my speakers didn't work, so I downloaded realtek driver for 7 and installed it. But my speakers still didn't work, when i open my speaker setup i get this picture:
    When I test them they all work except front left and front right, but i actually don't have 7.1 audio channel i have 5.1 and side left and side right are suppose to be front left and front right....I'm going crazy!!!
    Please help anyone.....
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Hi BlueClaw and welcome to Window 7 Forums
    Do you have the Realtek HD Audio Manager installed (orange/brown speaker icon in system notification area)? If so, right click on it and click Sound Manager.
    From here, you can check the operation of each speaker and also the socket assignments.
  3. Posts : 27
    Hi, where did you find the realtek drivers if you dont mind me asking? do you have the link, thanks?
  4. Posts : 5
    Ok here it is:
    Now how do I change the operation of each speaker and the socket assignments?
  5. Posts : 9,582
    You can find the link in the first post in this thread here: Latest Realtek HD Audio Driver Version
  6. Posts : 5
    Please help!!!!
  7. Posts : 1,114
    Windows 7 Home Premium 64 bit
    If you don't have a 7.1 setup don't use it, use the 5.1 that you have, then you'll have front left and right. Just a thought
    Smitty
  8. Posts : 5
    Nope..doesn't work...
  9. Posts : 9,582
    If you right click one of the sockets, you should get the following pop-up.
    Click on Connector Retasking... to bring up the following (will be similar to, but not identical).
    Select your option here and click OK.
    You will need to do this for each socket that you have connected.
  10. Posts : 5
    OMG!!! Thank you so much!!!!It works!!!!!
