How to connect PC's sound with LED monitor's speaker
  1. Posts : 20
    Windows 7 Ultimate 32bit
    My Speaker have been damaged for months. The audio comes buzzing tune. So. want the Pc's audio come from my LED Monitor that supports "USB" , ""ATV" , "AV" , "Component" , "HDMI" , "PC" and "USB".
    I want you guys to help me to take me out of this problem.
    Hope you'll.!! :)
    If your monitor is HDMI and supports HDMI sound, that is the only way I see, based on what you have reported. Otherwise, the monitor must have a 3.5mm jack for audio input and then you can connect a cable from the 3.5mm Speaker (Green) jack on the PC to the monitor.
  3. Posts : 20
    How to know that my computer supports HDMI sound or not??
    Please reply.
  4. Posts : 8,135
    Based on your listed specs, the PC does not support HDMI.
    If the monitor does not have a 3.5mm jack for audio input you will not be able to use the speakers in the monitor.
  5. Posts : 20
    "Based on your listed specs" what does this mean
    Can I use Speakers jack for monitor which has green jack at one end and red and white at another
  6. Posts : 4,161
    Windows 7 Pro-x64
    No one here can see your display or PC connections so we rely on the information YOU supply in your system specs. That's why it's important to supply exact make and model numbers so that someone can look them up to verify the available connections and make recommendations.
  7. Posts : 20
    I don't really understand what are you trying to tell, carwiz ..
  8. Posts : 2,047
    Windows 7 Home Premium 64-BIT
    If your monitor has built-in speakers, check for the speaker port (Usually it's colored green) or just use the HDMI Port
  9. Posts : 8,135
    He apparently does not have a HDMI port on the PC, again based on his listed specs. His PC only has 1.5GB of Memory and the video card has 256Mb. This suggests a very old PC.
    We are only guessing as not enough information on his PC and monitor have been provided.
  10. Posts : 20
    I added 0.5 GB of Ram myself wait, I again replaced my motherboard as it damaged by shutting down my PC by cutting of power Supply
    I really bought this PC on 2008 really
    I don't think my PC does support HDMI Port.
    Attached Thumbnails Attached Thumbnails How to connect PC's sound with LED monitor's speaker-untitled.png   How to connect PC's sound with LED monitor's speaker-1.png
