No output from front audio jacks :(
  1. Posts : 25
    I finished setting up my own custom built PC 2 days before and i noticed this problem.
    There is no sound output from the front audio jack. I'm using Asus motherboard. There was a similar question in their FAQ. I tried it but it didn't help.
    ASUSTeK Computer Inc. -Support-
    Please help me fix this :/
    My CPU configuration goes like this :
    CPU : AMD FX8350
    RAM: Corsair 8GB x 2 = 16GB
    OS: Windows 7 Ultimate 64-bit
    Video Card: AMD Radeon R9 270x 2GB
    Motherboard: Asus M5A97 LE R2.0
    Any kind of help is highly appreciated. :)
  2. Posts : 5,656
    Did you plug the front audio connector to motherboard yet?
    There should be a little plug called HD Audio or something similar, plug it on the appropriate connector on motherboard. Check manual to locate it. If it's AC97 then plug that one.
  3. Posts : 25
    I'll check it and will let you know :)
  4. Posts : 611
    Windows 8.1
    You may also want to check that the front audio drivers are installed correctly.
    Try following Driver Install - Device Manager
    Make sure that you use the find drivers Automatically if there are any identified with a warning symbol.
  5. Posts : 25
    Wooh! Thank you so much both
    I was just stupid enough not to plug in the audio cable into the motherboard. Plugged it in changed the mode to AC97 and it fixed it :)
    Thanks a lot
  6. Posts : 611
    Windows 8.1
    Thanks a lot
    Good to hear, glad its resolved!
