Burning Audio CD's
  1. Posts : 359
    windows 7 home premium 64bit
    Burning Audio CD's
    Good day to all.Maybe someone can help me out here.I have a fair amount of music on my pc,Now the problem I'm getting when trying to burn an album to a blank CD.I have tried using the windows media player and the CD BurnerXP Pro..CDBurnerXP Pro - Free download and software reviews - CNET Download.com .All goes well with the burning but the big bug is only one out of six will play on a CD player.
    I did one for my pal the other day it was a CD of irish jokes,Didn't work so tried another one no joy so he brought it back for me to try and no joy on four cd players.What am I doing wrong is it the discs or the burning software that I'm using,If so what is the best software to achieve this cd burning.
    PS have tried various burners over the month only problems I'm getting.
    Any help please.
    Many Thanks.
  2. Posts : 5,656
    The CDs may have compatibility issues with the drive. Search for a firmware update for your model.
    Drive may be going bad, can you check with another one?
    Are you using verify option in burner software?
  3. Posts : 359
    Yea thanks for the reply.
    .Are you using verify option in burner software?
    No Should I,Never thought about that.
    Is that option in the CD BurnerXP Pro?
    Thanks.
  4. Posts : 5,656
    You should, until at least this issue is sorted. Almost all burning software has some such option, check the settings.
    You can also try burning at a slower speed, x8 x16.
    See if CDs check out with these https://www.raymond.cc/blog/test-cd-...and-file-test/
  5. Posts : 359
    Thanks.
    I just had a go with the CDurnerXP Pro And burnt it on a 8 speed.and verified.
    Put the disc into my Bose player and it did not reckognise the disc,Then tried another player
    Been having this issue for a while,Just cant seem to get it sorted.Also did a check on the drive and all showed up okay windows said it has the latest updates.
    Thank You very much I much appreciate your help.
  6. Posts : 8,135
    The speed the audio CD's are burned at can be an issue with some Audio CD players.
    I do a lot of Audio CD burning, as I have a recording studio. I also make copies for customers. My audio CD burn speed standard is 8X, however with most SATA CD/DVD burners the lowest burn speed is 16X. I would try burning at the lowest speed of your drive and see if that helps. If you have an older system with PATA (IDE) CD/DVDE burners, 8X is usually available.
    CDBurnerXP will allow setting the burn speed. I don't use, I use Nero BurningROM, but I've looked at CDBurnerXP.
  7. Posts : 8,135
    After I made my post, I see where you did burn at 8X.
    Let me check CDBurnerXP and I'll get back.
  8. Posts : 359
    Sorry GoKay.I missed you posting.
    I will check that link out in a little while.Thanks.
  9. Posts : 8,135
    First, use CD-R's for burning audio CD's, NOT CD-RW.
    Here is the setup I used to burn an audio CD with CDBurnerXP
    Attached Thumbnails Attached Thumbnails Burning Audio CD's-burner.jpg   Burning Audio CD's-capture.jpg
  10. Posts : 359
    fireberd.Many thanks for that image,That is the same settings that I just tried.
    Something gone wrong somewhere.I will have a look for some other make of disc and try again and the disc id CD-R.
    Will let you know later.
    Thank You.
