Sound Card replacment for on board audio
  1. scr
    1. Windows 7 Home Premium sp1 - 64bit 2. Windows 7 Pro sp1 - 64bit
    I just purchased a New Windows 7 HP Envy computer (#2 in "My System Specs") with on board "Beats" audio.
    This may work well for some but most of my music is from the 40's through the 70's and Beats audio does a terrible job. The volume constantly changes and the audio will shift from left right and back. I am not an audiophile but to be quite honest it sounds horrible. It may sound great with today's music but I'm old. I've attempted to do adjustments but nothing seems to be able to get rid of the compression or the effects. Looking online I have come to the conclusion that there just isn't a fix for the issues. HP was no help.
    The only solution I can think of is to purchase a sound card and disable the on board audio. I've read that some sound cards do not work well with Windows 7 Pro and some do. I don't need the greatest but a software graphic EQ like Realtek has is essential.
    If anyone knows how to make the "Beats" listenable I'll give it a try. Otherwise, any recommendations will be greatly appreciated.
  2. Posts : 260
    Hi scr,
    Please can you go to Control Panel\Hardware and Sound and open the Beats Audio Interface - Please screenshot the interface and upload it to this thread.
    I can sympathise with you, the Beats Audio driver is terrible!
    MistUnleashed
  3. scr
    MistUnleashed said:
    Hi scr,
    MistUnleashed
    Thanks for the reply here's the screenshots
    It's big and ugly
    Attached Thumbnails Attached Thumbnails Sound Card replacment for on board audio-beats-1.png   Sound Card replacment for on board audio-beats-2.png
  4. Posts : 260
    scr said:
    MistUnleashed said:
    Hi scr,
    MistUnleashed
    Try these steps, they helped a friend of mine with exactly the same issue. A Warning though, this unlocks the full capability of your Audio Chip so DON'T have the system volume higher than 50% or you may damage your ears!
    Removing Beats Compression:
    1. Go To: Device Manager
    2. Go To: Sound, video and game controllers
    3. Click on IDT High Definition Audio CODEC
    4. Double-Click and Update Driver
    5. Select 'Browse my computer for driver software'
    6. Select 'Let me pick from a list'
    7. Select High Definition Audio Device
    8. Read the warning and click Yes if you understand the risk
    9. Restart computer
    After Your Computer Restarts:
    1. Go To: Start > Type: 'Sound' - open Windows Sound
    2. Click on your High Definition Audio Driver
    3. Click on the 'Enhancements' tab
    4. Go through the list and click on 'Loudness Equalization' and click 'Settings', then move the slider to 3/5 or 4/5 towards Long, then click on 'OK/Apply'.
    Let me know if this works for you.
    MistUnleashed
  5. scr
    Thanks but I do not have a "IDT High Definition Audio CODEC" showing in Sound, Video and Game controllers.
    Attached Thumbnails Attached Thumbnails Sound Card replacment for on board audio-device-manager.png
  6. Posts : 260
    Change the Realtek Driver as per my previous instructions.
    Let me know what happens.
  7. scr
    Sorry for the delay in responding, life gets in the way of fun way to often...
    WOW! What a difference....
    Only problem is my face is starting to hurt from the ear to ear grin,,,,,
    After I removed all the HP crapware off I was so happy to get this computer. Then I played a tune or two. My joy went right down the tubes. You have restored my enjoyment of my new system... I had given up on finding any way to get this to work.
    I can't thank you enough.
    One question is there any type of EQ associated with this set up? If not it's really not a big deal as I use WinAmp and it has a EQ. I can probably figure out a way to run my XM receiver through it.
    Again, my most sincere thanks for taking of your time to help me.
  8. Posts : 260
    No problem! That's what we're all here for! - Plus I couldn't let someone listen to music using a sub-par quality sound driver like Beats Audio - Its just a gimmick and a selling point for HP!
    Yes there is an EQ - But only really for the bass, but it does affect the treble (if that helps) :
    4. Go through the list and click on 'Bass Boost' and click 'Settings'
    5. To keep your vocals clear, boost by no more than 15dB at around 50Hz for a clean and tight bass note or 'boom'
    6. For 'More Bass/Enhanced Bass' boost to 75Hz-100Hz (Depends on your user preference)
    7. Then click on 'OK/Apply'.
    Hope this helps! Let me know how it goes!
  9. Posts : 5,656
    Hey Mist, I have two questions:
    - You installed the generic Windows audio drivers, yes? Would it not be better if Realtek drivers were installed?
    - Would it be possible to disable with just unchecking "Beats Audio" in the 2nd screenshot?
    Thanks!
  10. Posts : 5,656
    Is the Realtek driver from manufacturer the one that has Beats built-in? How about drivers from Realtek website or WHQL from Windows Update Catalog (see sticky thread)?
    The second answer is cut in half, missing the 2 things you mention :)
