Sound is too loud
  1. Posts : 16
    Windows 7 Ult 64
    Sound is too loud
    Hello.
    I have a Creative Audigy RX and after I changed my headphones for another headphones without volume control on it, and I started getting annoying issue: overall volume in Windows 7 is very very loud. It set to 5% currently, but still loud. I don't know what to do. I've checked all Windows 7 and creative settings, but it seems I can't find anything what cause this issue.
  2. Posts : 5,656
    See if this helps Audio too loud on earphones
    If not see Windows 7 Audio Too Loud - Super User
    Sound > Default Device > Properties/Levels.
    Scroll down to the bottom
    Front will be at 100. (Strange since I use stereo headphones.)
    Lower it to 10.
    You can try setting it to 5 or less.
  3. Posts : 16
    Windows 7 Ult 64
    Thank you, but it doesn't help since I have a creative, not realtek. Also i don't have a audio enhancements in the control panel...
