Strange daily 'alarm' noise from PC
  1. Posts : 92
    Win 7 64bit SP2?
    Windows 7 x64 fully updated (but obviously not up to Win 10!)
    I'm at a total loss (never hard!) as to what's perpetrating this problem. Over the past week or so, my PC is making the noise attached regularly at the same time each day for 30 secs. To my knowledge I've not set up any alarms on schedule with any program etc and have checked all running processes etc during it but nothing's standing out as an obvious culprit. Strangely it's not affected by muting the PC sound - it just keeps on going!
    Typical programs running at the time are:
    Outlook 2010
    Itunes
    Picasa3
    BitDefender
    Thanks in advance :)
    Anyone any suggestions as to what to check out perhaps.
    Strange daily 'alarm' noise from PC Attached Files
  2. Posts : 1,670
    win 10
    hi
    is the sound coming from your speakers or from the case itself?
  3. Posts : 92
    Win 7 64bit SP2?
    It's defo from the case as it keeps on going despite speakers being turned off
  4. Posts : 1,670
    win 10
    try reseating the ram
  5. Posts : 92
    Win 7 64bit SP2?
    Appreciate the suggestion, but unsure why a RAM issue would cause a 30-sec "alarm" at exactly 22:37 each night? It's definitely the strangest thing I've had happen to my self-built machine in its 3 years since replacing the MB. But yes, the RAM was changed recently (about 3 wks prior to the noise) so certainly a possibility perhaps. Will check it out tomorrow all being well & see if any difference. Thanks
  6. Posts : 4,776
    All I can suggest is checking scheduled tasks to see if anything is set to run at that time.
    You can grab yourself a copy of portable TaskSchedulerView
    Download links are at the bottom of the page and you need "Download TaskSchedulerView (32-bit)" for your system.
    Extract the files into a folder somewhere and run the executable. Check the "Last Run" and "Next Run" columns to see if anything runs at that exact time.
  7. Posts : 92
    Win 7 64bit SP2?
    Thanks so much for that Callender - thought you might have cracked it but no - sadly nothing shows up at all in the list for 22:37 daily. Plus I figure perhaps it's not a Windows issue in the sense that the sound is coming from the MB or case or something that direction.
    Are there alarms in the BIOS or the like - anything like that for the CMOS battery? The MB is a Gigabyte one but it's only a year old so unlikely I suppose, but things can fail. Just thinking out loud, but please fire me any other thoughts on it, as it's really becoming quite annoying because you can't turn it down/off so it interrupts everything.
  8. Posts : 1,670
    win 10
    did you try that yet? you could always check bios settings but never seen anything in bios for an alarm.
  9. Posts : 4,776
    Well it was worth looking at scheduled tasks. I can find some information on "Beep Codes"
    Understanding Beep Codes on a Dell Desktop PC | Dell US
    I have no experience of troubleshooting such issues.
  10. Posts : 25,847
    Do you have anything in msconfig/startup or services that do auto updates or check for updates. I personally don't allow any auto updates of anything and that includes uploading anything into a Cloud.
