Yes it is but I'm not sure that is what kwitel is referring to.
Before walking the dog sideways any longer I would like to be sure. I know what I'm working with for sure.
Jack-
My apologies if I wasnt clear in my initial post; I very much appreciate the time you have put in thus far.
Everything from my initial post was correct with the exception of the speakers.
I had thought they were emitting static but it appears now they are not.
They aren't very good speakers to its possible I just didnt give them too much credence upon first listen.
That said, I am definitively using an Audio Advantage Micro II by Turtle Beach (your link above is correct). Its a USB Sound Card/Digital Adapter dongle, that my Grado Headphones plug directly into. The AAM2 is plugged into the back of my Dell Optiplex.
I am not sure why I am not getting any static out of the speakers.
I did try the Grado-->AAM2 on my laptop and got no static, so i assumed the AAM2 was working properly.
I was asked to help on this problem, but I'm unsure what the exact problem is.
As I see it you have Grado Headset and a Dell OptiPlex laptop. What is the Audio Advantage Micro? From your original post it appears you are using the laptop. Does the laptop speakers have the "static"? Is the "static" when its using AC power only or does it also do it when the laptop is on battery?
More specific on exactly how you are setup is needed. I went through all the posts and just got confused.
I'm a bit confused reading this thread too, just posting here to subscribe to updates for now.
Ah I see:
So with the following setup you get low level static sounds through your earphones:
Earphones -> USB Sound Card -> Dell Optiplex
If you are using the USB sound card, as a first step disable the internal sound card, in the BIOS, on the OptiPlex. Two sound cards can cause conflicts. Eliminate the potential before continuing with troubleshooting.So with the following setup you get low level static sounds through your earphones:
