System Manufacturer/Model Number: The Cloud Windfoot Omega Build. Codename: Outpost OS: Windows 7 Pro 64bit CPU: Amd 550BE unlocked to Quadcore 3.1GHZ Motherboard: GA-770TA-UD3 Rev 1.0 Memory: 4GB OCZ platinum 1333 Graphics Card: ATI 3850 512MB Asus Sound Card: creative Xfi music Monitor(s) Displays: samsung syncmaster T220+ Dell P780 Screen Resolution: 1680x1050, 1280x960 Keyboard: Microsoft natural ergonomic 4000 Mouse: Logitech G9 PSU: Ultra 500 watt Case: some random case Cooling: Coolmaster TX3 Hard Drives: WD 250GB
segate 500GB Internet Speed: Teksavvy 5Mbps down 700Kbps up Other Info: there is a 80mm(8cm) intake fan on the side of the case and a 120mm(12cm) fan as exaust
System Manufacturer/Model Number: Dell Optiplex GX620 mini tower OS: win 7 32-bit CPU: Pentium D 2.8Ghz Motherboard: Dell 0HH807 Memory: 4gb Graphics Card: Radeon X600 Sound Card: integrated Monitor(s) Displays: 1x 17" analog, 1x 19" digital Screen Resolution: Both 1280x1024 Keyboard: Dell media sk-8135 Mouse: lil dell optical with fwrd and bck bottons on it :) PSU: 305w Case: Dell Optiplex GX620 mini tower Cooling: needed Hard Drives: 2x80gb Other Info: 3 port IEEE PCI card (rarely in)
Hauppauge WinTV 26552 Tuner/Capture card
I'm a car guy but I got "a great deal" on my system and I want to upgrade it to make it a cool lil machine that can rival the one with fancy cases. Eventually this will be my HTPC. I might keep it all this this case as I become more experienced to give it that sleeper look
sure, only reason i dont really know is im not sure if it is the same setup. but if it is the back speakers will have horrible bass in contrast to the sub
Hi all looking in vain for Surround Sound System, that isn't a dvd/Blu-ray player or a AV Amp System, just need it to work for sound 5.1 or higher with a sub out, optical in, is there such a thing ???
cheers web
hi......i recently brought sony32EX650 LED TV with Sony DVD player with home theater.and i want to watch HD movies on this TV with surround sound but we know dvd player don't play the Hd quality videos.But on TV's usb we can play those Hd videos and they have 5.1 surround sound also.and i can't get...
Hi all. Upgraded my OS from XP to Win7 (again) Before I had just headphones.. Now I have problem.
My sound card Realtek ALC883 @ VIA VT8237A High Definition Audio Controller
Cpu AMD Athlon 64, 2200 MHz (11 x 200) 3500+
Motherboard Asus M2V-MX (2 PCI, 1 PCI-E x16, 2 DDR2 DIMM, Audio, Video,...
Hi.
I have a ASUS LGA1156 Intel P55 DDR3 - 2133 ATX Motherboard
I was told this mobo has surround 5.1 integrated with it.
I just do not understand how to use it, or at least I think I don't.
What cable do I need and what slot do i have to connect it to.
I've recently found out that my sound card application (creative audigy) is not compatable with win7 and have yet to find any creative programs that work with my computer. Is there a way around this to still be able to play music on 5.1 surround sound? Like a generic application to play music in...
