c media help need drivers
  1. Posts : 26
    windows 7
    i instaled win7 and i'm happy ... everything is fine mine sound card on MB is working...
    but i have 2 sound card.. /music powa/ i can't detect second one
    informations i have about her...
    PC TV CAPTURE INTEX
    An ISO 9001:2000 Company
    VER:FM 0412
    [MSILoader]
    MSIFileName=TVR.msi
    __________________
    win 7 will instal u! :=)
  2. Posts : 5,747
    7600.20510 x86
    Hi.
    Right click on it in the device manager. Properties. Details tab. Change dropdown to hardware ids. Copy and paste (no screenshot please) the results to here.
    I'll either find or make you a driver to install.
    Do you need x64 or x86?
  3. Posts : 1,614
    Windows 7 Pro & Vista Home Premium
    Try going to Start > Run, and type msinfo32, expand the Components section and click o Sound device.
  4. Posts : 26
    windows 7
    torrentg said:
    Hi.
    all it's write is this...
    PCI\VEN_13F6&DEV_0111&SUBSYS_011113F6&REV_10
    PCI\VEN_13F6&DEV_0111&CC_040100
    enything else?
  5. Posts : 5,747
    7600.20510 x86
    That's fine but do you need x86 or x64?
  6. Posts : 26
    windows 7
    i don't get it... what do u mean..?... what is beter or that's must match with OS?
    help a litle bit? pls :=)
    if some help my system type is 32-bit
  7. Posts : 1,614
    he means are you running the 32-bit or 64-bit edition of Windows 7.
  8. Posts : 26
    windows 7
    i write it,my friend... read beter... :)
  9. Posts : 5,747
    7600.20510 x86
    Yeah. It has to be the same as the version of Windows 7 you installed.
    They have never even made a Vista driver for it. So you could try the XP driver if you want.
    They're located here. <<< Use I.E. You'll have to open the .inf and make the line with this - VEN_13F6&DEV_0111
    become this instead
    then save it.
    Right click in the device manager on it. Update driver software. Browse. Let me pick. Have disk. Browse. Now double click on the .inf you edited and hit ok. Then click next and let it install.
    It's probably not going to work, but worth a shot.
    If you want to see which version of Windows you have, type system information in the start menu search box then hit enter. Look at the system type line.
    Good luck.
  10. Posts : 26
    windows 7
    become this instead
    then save it.
    Good luck.
    can u send me on mail.. or upload that on rapishare... i use opera and i can't open that download link... !!
    holy crap...
    mail: kico-roler@hotmail.com
