Windows Audio service not running ! But it is ?
Page 1 of 6 123 ... LastLast
  1. Posts : 40
    Windows 7 Ultimate Media Center Edition
    On occasion when i boot up im getting a red cross on my volume control in the tray and hovering over it it says the "audio service is not running" but the service is running, i get sound and everything is working fine. Looking at the services i find windows audio service and yep its running fine & set to automatic but there is still the red cross in my tray?
    at the moment im having to "restart" this service to get rid of the notification and the red cross but its a pain.
    Only happens about 20% of the time.
    I have the latest sound drivers.
    have done a search but its all about this service failing to start & giving errors etc.
    any ideas anyone,
    Thx all,
    JackDinn.
  2. Posts : 4,573
    Isee that you have listed: OS Windows 7 Ultimate Media Center Edition.
    Hmm. Maybe there's a connection.
  3. Posts : 40
    well i dunno is that a statement or just a thought.
    Seem Im finding all the little bugs n win7 , lol well thats me if these a bug i'll find it. :P
  4. Posts : 9
    windows 7
    mine does exactly the same as JackDinn describes
    the service is actually running but tray icon says differently
    minor pita but nicer if it did what it was supposed to do
    simply restarting the service makes the red cross go away
    i have also noticed some other erratic issues with other tray icons as well
    possibly it's general issue with windows 7 as it never did such things with vista
    addendum
    booted the pc tonight
    audio service had the red cross
    clicked on it
    volume slider opened
    adjusted volume
    red cross went away
    go figure
  5. Posts : 40
    hmm, will adjusting the volume do the trick ? i shall try that next time it occurs
    Thx.
  6. Posts : 14
    Windows 7 32 bit
    addendum
    clicked on it
    adjusted volume
    red cross went away
    go figure
    Same here.
    Just tried adjusting the audio as suggested and the red cross disappeared.
    What gives?
  7. Posts : 1
    Windows 7 Professional 64bit
    addendum
    clicked on it
    adjusted volume
    red cross went away
    go figure
    Same here.
    What gives?
    No ideas here either, I simply pressed the mute button on my keyboard a couple of times and the cross disappeared as well. Gotta love the bugs
    Oh well, a bug like this is easy to work with and I'm sure they'll fix it eventually.
  8. Posts : 1
    Win 7
    Same problem here, thanks for the quick fix. Adjusting the volume on the slider worked for me too. :)
  9. Posts : 30
    Windows 7 Home Premium
    Works for me... thanks.
    A real solution to the bug would be nice.
  10. Posts : 1
    Gheto blaster SE
    I got this problem too for the very first time today. Adjusting the volume just fixed it.
    Also, sometimes when i delete an item in windows explorer, the item does not disappear, it just stays there as if i had no deleted it, although, i cannot use it, refresh does nothing, but if i browse to another folder, then return, it will be gone -
    -So i wonder if this is happening for a similar reason?
