No audio sound
  1. Posts : 147
    Windows 7 Professional
    No audio sound
    I've just spent the last 1.5 hours grappling with this problem that happens frequently. I have Logitech speakers which are properly connected (green light on), I have checked: Device Manager, both Intel(R) Audio Properties and Realtek HD Audio "device working properly, gone into services.msc/all necessary services Started/Automatic, checked the Volume icon does not have a red check, etc.. (I am unable to do chkdsk or sfc /scannow: the command prompt boxes flash for a second and then disappear!) This is such a vexing problem. As always, your help is greatly appreciated. ellenc
  2. Posts : 7,107
    Hi Ellen,
    is there a Audio manger in control panel.
    try running dskchk/sfc from an elevated command mode.
    Roy
  3. Posts : 147
    No audio playback
    I honestly believe I couldn't survive my computing life without this forum. Thank you ever so much for your help. I was joyous when I heard sound blasting from the speakers. ellenc
