Audio doesn't work on my ViewSonic VA2265Sh
Hello there good people!
I recently bought a new monitor for my desktop and set it all up no problem, but for some reason, I haven't been able to make the sound work. So far, I've tried the usual solutions (I've checked out whether the speakers were the default device, reinstalled all drivers and tried a few others, and checked whether my headset still worked, which it does). The monitor itself uses an HDMI output and has an additional jack for VGA input, so I tried using both at the same time to no avail. What's really bothering is that the system itself says everything fine and even registers audio, but the speakers don't respond at all.
I'm sending you an Amazon link that shows the monitor I'm trying to use Amazon.com: Viewsonic Value VA2265Smh 21.5" LED LCD Monitor - 16:9 - 5 ms: Computers & Accessories
Also I have a Geforce GTX 770 and I tried changing between the NVidia and the "normal" high definition drivers, and still nothing. I'm beginning to think this might be a hardware problem...
If anyone could give me some advice as to what to do, I'll be extremely grateful. And at any rate, thank you for your time!
