Windows 7: No Audio Output Device Installed Error (Code 52 on my audio devices)
03 Feb 2017   #1
TheSev7enSeas
Windows 7 Professional 64bit
Hello there,
I have an error in my Windows 7 with the audio, "No Audio Output Device Installed."
I checked the playback & recording devices, but none are installed. I checked for hidden devices, but there wasn't any.
So I opened the Device Manager, and checked the "Sound, video, and game controllers" tab.
I have two audio devices with the same error:
Intel(R) Display Audio
These two devices have this error (code 52):
"Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)"
((Edit; This is the first thread I made on these forums, and this problem came up just today. Yesterday, the audio was OK. And please be quick as you can, because I can't be on a PC without audio. ))
03 Feb 2017   #2
fireberd
If you have a recent System Restore point, restore the PC with that restore point and see if that fixes the problem.
If not, Uninstall both Intel and Realtek sound in the Device Manager. DO NOT uninstall the drivers. Restart Windows and they may be detected and installed when Windows starts.
The third possibility is malware. Do a malware scan with Malwarebytes.
04 Feb 2017   #3
TheSev7enSeas
I tried uninstalling both of them, that didn't work.
So I tried System Restore, and it actually worked.
04 Feb 2017   #4
fireberd
Great.
No Audio Output Device Installed (error code 28)
Hi there, So when I woke up my computer from sleep this morning, for whatever reason, the sound didn't appear to be working. Nothing seemed to be amiss, but I simply wasn't getting any sound. When I clicked on the speaker icon and tried adjusting the volume, the bar would show up, but there'd be...
No Audio Output Device is installed, HDMI Audio Out Works
No sound. Little speaker with the red 'x' appeared yesterday I have gone through the whole update drivers circus to no avail, my laptop can't detect that it has speakers built in so it doesn't bother finding a driver for them. This is where I am at: - Intel Display Audio is the only driver...
No Audio Output device is installed. CODE 10.
I would literally kiss the person even if I have to cross the seven seas if he/she gives me the solution to this goddamn problem! CPU: Dell Optiplex 745 OS: Windows 7 Enterprise x64 RAM: 2GB Processor: Intel(R) Core(TM)2 6700 2.66GHz Hard drive: 250GB Graphics card: Nvidia Geforce 210 (1GB)...
No audio output device Is installed error
Hey there, I'm getting the error on my volume; "No audio output device is installed" Any fix for this? Thanks in advance. :cry:
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
