Windows 7: My earbuds making a low noise when connected to, or touching, the PC
01 Mar 2017   #1
rafael91
Windows 7 ultimate 32-bit sp1
Earbuds making a low noise when connected to, or touching, the PC
I bought a pair of earphones and it's working perfectly. However When I connect it to my PC it makes a low buzzing sound. The same thing happens when the jack touches any part of the computer where there's metal (e.g. the chassis, hard drive, etc.) even if the computer is turned off (but plugged in). The weirdest part is that the buzz stops only when I touch any metallic part of the computer and when I release, it starts again.
Some help would be appreciated
01 Mar 2017   #2
sml156
Microsoft Windows 7 Ultimate 32-bit 7601
Sounds like a ground problem.
Check all plugs and power cable's for the ground pin, If it's damaged or missing replace it.
02 Mar 2017   #3
rafael91
Quote   Quote: Originally Posted by sml156 View Post
I'm not using three pin plug; just two pins, but thanks anyway
02 Mar 2017   #4
sml156
I am talking about the power cord, 120 volt cord that plugs in the wall not your headphone cord.
02 Mar 2017   #5
rafael91
That's what I'm talking about too. Double pin power cord works at 220V. I live in Syria :)
02 Mar 2017   #6
sml156
Quote   Quote: Originally Posted by rafael91 View Post
I can't help you then.
The only thing I can suggest is to do a google search for
ground problems hum in speaker 2 prong plug 220 volt
02 Mar 2017   #7
rafael91
Ok thanks
CPU fan making noise
I have an AMD Phenom II x4 955 cpu with the factory mounted fan on top. Have noticed lately that a pronounced noise (squeal) from the fan when viewing various sites with my browser. The fan speed adjusts with the content as expected. Now it is running @ 3900 rpm while typing this, but if I...
Hardware & Devices
Noise when touching laptop keyboard or bezel
Shuffling paper, scratching bezel or touching keys on laptop keyboard creates magnified noise some of which is very high pitch, heard through the speakers, but inserting ear piece jack kills the sound which is not heard through the ear piece or when the earpiece jack is inserted. Unplugging laptop...
PSU making a lot of noise
I have Thermaltake Toughpower 800W PSU! Its fan makes really loud noise when playing PC games! I tried to oil the fan like I did with my CPU fan, but I could not get to PSU fan without opening the PSU itself! Should I open it? Or maybe there is another way to fix this!
Hardware & Devices
PSU making a noise
My computer has started to make a bit of noise...it sounds like a faint hum, or constant drone, kind of like a fan noise. I checked the intake, exhaust and cpu fans by stopping them spinning and the noise is still there. It sounds like its coming from my PSU. Does that mean its on its way out? I...
Hardware & Devices
PSU making noise!
My PSU just started making a noise, like if something's touching the fan. It's a different computer from the one in my specs. It's a sturdy black one, however this PC has no case and the PSU is positioned in a way that the fan is on top and sucks in air, so a lot of dust goes in. Since September it...
Chillout Room
