Windows 7: Possible sound 'permissions' problem?
15 Mar 2017   #1
Steve the Sax
Windows 7 pro 64bit
This one has me foxed.
Recently did a fresh install of W7 pro 64 on a new Dell desktop, and all went well.
After installing a number of updates over a period of time I noticed that I'd lost my system beep...specifically the caps lock warning.
I also noticed I'd lost a number of 'incidental' app sounds...such as an audible warning to accompany a 'delete this file?' message. All the other sounds seem fine (at least the ones I'm aware of). All the sounds work in the Control Panel sound applet.
And then last month I downloaded and installed a batch of Windows security updates, rebooted - and lo and behold, all the incidental sounds came back...until I rebooted again.
Did exactly the same thing this morning - downloaded the updates, rebooted and got my sounds back until I rebooted again.
I then found that Photoshop (CS3) was throwing up an error when saving files, telling me the files were locked. I'd been running it in admin mode, but found it worked in standard mode (and didn't throw up a UAC warning)....and when it switched it back to admin mode it saved the files just fine. It continued to save them just fine when I switched it back to standard mode.
This has got me thinking that the sound and the Photoshop issues are related in some way, specifically to permissions...but above and beyond that it's way out of my usual 'tweak the registry' comfort zone.
Anyone got any ideas, pointers, words of comfort?
Cheers,
Steve
25 Apr 2017   #2
DealerMan
Microsoft Windows 7 Ultimate 32-bit 7601 Multiprocessor Free Service Pack 1
Steve, I'm certainly no expert, but I can't figure out a link between Photoshop and your sound issues. I'm thinking a sound driver reinstall might be worth a shot. Try it and let us know what happens.
Keep us posted, Good Luck!
27 Apr 2017   #3
Steve the Sax
Windows 7 pro 64bit
The Photoshop thing turned out to be something else. Somehow the permissions on an entire partition had been changed. I still have no idea how that happened.
As for the sound issue, it remains. Had another security update recently, same results - installed the update, reboot, sounds come back. Reboot again, gone.
Have tried reinstalling the sound driver - no effect.
28 Apr 2017   #4
DealerMan
Steve, are you running with on-board sound, or a dedicated audio card? If dedicated, is your BIOS disabled for on-board? Have a look to be sure. Just to be safe, you might try re-seating the card as well. Also, are you just using standard wired speakers, no bluetooth?
14 Jun 2017   #5
Steve the Sax
Windows 7 pro 64bit
It's on-board sound (Realtek), bios is set for on-board audio - and the speakers are standard wired.
Just installed a security update today, and as usual I have my 'delete' sound back as well as the caps locksound (system beep) on reboot...but, as before, it's likely to disappear on the next reboot.
I've cleared the event logs in the hope that something might pop up that'll provide a pointer.
Permissions Problem ??
I fitted a spare 500GB HDD in a Windows-7 Pro 64-bit machine (machine AA). It's called drive F:/ I filled it with photos across the network from an XP machine (machine BB). I had full access to \\AA\F for a few days from \\BB. Later I had reason to put the UAC up to full and then back down...
Network & Sharing
windows 7 permissions problem
i am recently reinstalled windows 7 on my laptop.now i am facing a new problem when ever i want to acess folders/files on other partitions it is saying acess denied. then i have to take ownership of that file & i have to change grant permission to current user for each and every file. i have...
General Discussion
Another permissions problem
I have been trying frantically to delete the "Windows Defender" folder from my new PC as I have a much better anti-malware program. After reading probably 20 posts about people having the same "You require permission from X" issue as I was, I have changed ownership to administrator accounts (mine...
General Discussion
Permissions Problem
Hey, I'm trying to paste a .dll file into system32 for my program but it keeps denying me because i don't have permission even though im on as administrator... how can i setup permissions properly so i won't get this issue again on any thing on my OS, i managed to rid of it on vista but i...
General Discussion
Odd Permissions Problem
I have recently updated to build 7077 (from 7000). I have noticed some strange problems when trying to write new files. Sometimes Windows will tell me I do not have the proper permissions to write to that location (such as when installing an app to the Program Files x86 folder or saving a Maya file...
General Discussion
