Help with sound devices
Hello I installed a reboot system and now I'm gone Stereo Mix I wanted to know how to return it?
Usually, installing the correct sound hardware driver (e.g. Realtek, Conexant, etc) is needed. If you only have the generic, basic function Windows Installed High Definition Audio Driver (Codec) that does not include Stereo Mix.
However, if it is available, go to the Sound Panel, Recording section. RIGHT click in a blank area in that panel and then LEFT click to Show Disabled and Disconnected Devices. If Stereo Mix is available it will now be listed and you can set it as default.
System specs are needed for further assistance. PC Brand and Model Number or motherboard brand and model if its a custom built.
Here is another suggestion. A tutorial by Brink.
System Info - See Your System Specs - Windows 7 Help Forums
Jack
If you have Windows 10, we have a forum specifically for Windows 10 Windows 10 Forums
Here is an alternate site to download speccy
Download Speccy 1.30.730 - FileHippo.com
