Windows 7: Help with sound devices
05 Apr 2017   #1
moran32
Windows Home Premium 32bit
Hello I installed a reboot system and now I'm gone Stereo Mix I wanted to know how to return it?
05 Apr 2017   #2
fireberd
Usually, installing the correct sound hardware driver (e.g. Realtek, Conexant, etc) is needed. If you only have the generic, basic function Windows Installed High Definition Audio Driver (Codec) that does not include Stereo Mix.
However, if it is available, go to the Sound Panel, Recording section. RIGHT click in a blank area in that panel and then LEFT click to Show Disabled and Disconnected Devices. If Stereo Mix is available it will now be listed and you can set it as default.
06 Apr 2017   #3
moran32
Hi I've installed DoubleTree Realtek and still do not have a Stereo Mix
06 Apr 2017   #4
fireberd
System specs are needed for further assistance. PC Brand and Model Number or motherboard brand and model if its a custom built.
06 Apr 2017   #5
moran32
How do I find all the details?
And this desktop computer is not only portable to general knowledge
06 Apr 2017   #6
fireberd
Speccy program may help you.
Speccy - System Information - Free Download
06 Apr 2017   #7
Layback Bear
Here is another suggestion. A tutorial by Brink.
System Info - See Your System Specs - Windows 7 Help Forums
Jack
06 Apr 2017   #8
moran32
Quote   Quote: Originally Posted by Layback Bear View Post
Jack
I have Windows 10
06 Apr 2017   #9
moran32
It does not let me download
06 Apr 2017   #10
fireberd
If you have Windows 10, we have a forum specifically for Windows 10 Windows 10 Forums
Here is an alternate site to download speccy
Download Speccy 1.30.730 - FileHippo.com
Hello I installed a reboot system and now I'm gone Stereo Mix I wanted to know how to return it?:doh:
Sound Devices Have Disappeared
Have a Gateway M-Series laptop that came with 32 bit Vista Home Premium installed. We upgraded to Windows 7 Home Premium (also 32 bit) several years ago and have had no problems until recently. We have no sound. The speaker icon in the system tray has a red X to the right of it. Clicking on it...
2 sound devices
I sometimes get a bump sound from the speakers when i access certain websites followed by some video shudder (usually on my second screen only). I have an AMDRadeon HD5970 dual GPU card. I am looking in device manager and see the following: > AMD High Definition Audio Device >...
scratching sound even if all sound devices disabled
Hi, In my headphones, I ear a constant scratching sound even if all sound devices are disabled (playback and recording). Where can comes this sound ? What can I try ? Regards,
Sound Through Two Devices
Ok, first my hardware: Bose Companion 3 Interface - 3.5mm Stereo Jack Insignia Portable USB Speakers Interface - USB What I would like to accomplish is to have Windows 7 play sound through both of these devices at the same time. My reasoning for this is that I have my...
