Windows 7: Audio Buzzing loud after a sound is played.
16 Apr 2017   #11
fireberd
It would be strange to have the same identical hardware problem in two motherboards.
When you run Audacity, do you have any other application open that uses audio?
16 Apr 2017   #12
DarkShadowRage
Windows 7 Professional 64bit
I have Xsplit open that does use audio
16 Apr 2017   #13
DarkShadowRage
Okay so I think we found the problem, It WAS due to xsplit being open. When I closed Xsplit, the buzz went away.
16 Apr 2017   #14
fireberd
Cool. Problem solved. :)
16 Apr 2017   #15
DarkShadowRage
I do have a question though, is there any reason why xsplit would interfere like that and make it buzz?
Also Thank you for your help!
17 Apr 2017   #16
fireberd
I know nothing about xsplit.
But, you should have Stereo Mix set as the default Recording device. Whether that makes a difference??
IDT High Def Audio, buzzing sound when playing any sort of audio.
Hello, Starting about a week ago whenever any audio is being played through my computer (speaker or headphone) I will hear a buzzing sound and occasionally the audio with skip. This happens weather I am playing audio that is being streamed from the internet or that is on my computer directly....
Artifacts in post and monitor freezing with loud buzzing sound
Hello there,i really need you help ! So i bought a new graphics card,the Radeon R9 290 and i have the following problems 1)When i post up the pc instead of the BIOS image i am getting those random artifacts http://i57.tinypic.com/vhrm0n.jpg 2) In random times my monitor freezes with...
Graphic Cards
Loud buzzing noise before bsod
system fine all day was playing poker on 2 screens - put the footie match on after 5 mins everything froze heard a buzzing noise from speakers then bsod code 124(hardware) 3 weelks on off - i have checked everything
BSOD Help and Support
xonar d2x sound card loud buzzing noise problem
I am using xonar d2x sound card and it has been good until recently when I played videos on youtube and games it gives a loud buzzing noise. Even sounds made by windows sound produces the loud buzzing noise. It also happens on sometimes when playing videos. Other than that it works fine. I tried to...
Audio noise when first sound is played built-in Realtek
Hello. I want to ask a question about my problem. I tried to search about my case, but it's seems I'm the only one in this world who has problem like that. I have Asus P2W DH Deluxe motherboard with buit-in Realtek audio card (ALC882). My 5.1 audiosystem is connected via analog outputs. A...
