Windows 7: Audio Buzzing loud after a sound is played.
15 Apr 2017   #1
DarkShadowRage
Windows 7 Professional 64bit
Hey guys, i've had this problem for a long time and i have NO idea what causes it to do this.
Here is an example of what I mean.
Audio Buzz.wav - Google Drive
I don't know what causes this, it'll do this after a sound stops playing or whatever else.
PC specs:
* Windows 7 Professional 64bit
* Intel Core i7 4790k at 4.0ghz
* 3 hard drives totaling up to 3TB
* Nvidia Gigabyte G1 Gaming GTX 1080 8GB
*32 gigs of corsair vengeance pro ram
*Acer Predator XB271HU bmiprz 27" WQHD (2560x1440) NVIDIA G-SYNC IPS Display 144hz(Primary Montior)
*Asus VX24A 23.8" 1440p LCD Monitor(Main Monitor)
16 Apr 2017   #2
fireberd
That sounds more like a defective input connection???
16 Apr 2017   #3
DarkShadowRage
a defective input connection? as in things aren't connected in all the way? i made sure everything was plugged in securely.
16 Apr 2017   #4
fireberd
That was my first thought. I'm a guitar amp tech and if something is loose, bad connection, bad cable, etc it would cause noise such as that from an amp.
16 Apr 2017   #5
DarkShadowRage
that's odd, my motherboard is an asus z-97a and to be fair it happened on a previous motherboard too, but i don't think it's the motherboard though, kinda crazy that same problem would show up on a brand new motherboard too out of no where.
16 Apr 2017   #6
fireberd
That sort of agrees with what I said, that possibly an input is causing it. If you used the same case with the new motherboard, could be the front panel mic connection. Or if you use the same input devices (e.g. mic).
Mute any input port and/or device and then see if it still happens.
16 Apr 2017   #7
DarkShadowRage
well i did use the same case with a new board, however there is no front panel mic connection on this case however. all my connections are in the back.
also my MIC is a USB blue yeti. so it doesn't even connect to that at all and this happened even before i had my blue yeti.
16 Apr 2017   #8
DarkShadowRage
do you think maybe it could be my speakers?
16 Apr 2017   #9
fireberd
If you have a headset, disconnect the speakers and connect the headset to the GREEN speaker jack on the rear and see if you still get the noise.
16 Apr 2017   #10
DarkShadowRage
just tried it, and it still does that buzz noise when i stop it in audacity.
IDT High Def Audio, buzzing sound when playing any sort of audio.
Hello, Starting about a week ago whenever any audio is being played through my computer (speaker or headphone) I will hear a buzzing sound and occasionally the audio with skip. This happens weather I am playing audio that is being streamed from the internet or that is on my computer directly....
Artifacts in post and monitor freezing with loud buzzing sound
Hello there,i really need you help ! So i bought a new graphics card,the Radeon R9 290 and i have the following problems 1)When i post up the pc instead of the BIOS image i am getting those random artifacts http://i57.tinypic.com/vhrm0n.jpg 2) In random times my monitor freezes with...
Graphic Cards
Loud buzzing noise before bsod
system fine all day was playing poker on 2 screens - put the footie match on after 5 mins everything froze heard a buzzing noise from speakers then bsod code 124(hardware) 3 weelks on off - i have checked everything
BSOD Help and Support
xonar d2x sound card loud buzzing noise problem
I am using xonar d2x sound card and it has been good until recently when I played videos on youtube and games it gives a loud buzzing noise. Even sounds made by windows sound produces the loud buzzing noise. It also happens on sometimes when playing videos. Other than that it works fine. I tried to...
Audio noise when first sound is played built-in Realtek
Hello. I want to ask a question about my problem. I tried to search about my case, but it's seems I'm the only one in this world who has problem like that. I have Asus P2W DH Deluxe motherboard with buit-in Realtek audio card (ALC882). My 5.1 audiosystem is connected via analog outputs. A...
