Volume Control is not there
  1. Posts : 57
    Well folks, I have a Windows 7 Home Edition laptop here that belongs to an 82 year old widow from church that has no Volume Control. The Volume Control is not there. It is listed when I run the Customize option and choose the System icons, but the option is grayed out and cannot be turned on. And wouldn't you know, the sound is turned way up too, so I stuck a plug into the headphone jack to quiet it down. I can't even control the volume with the function key and the appropriate F key. I've tried everything I can find here and every other place Google showed me, but no success. I also uninstalled all the sound drivers, ran the Trouble shooter, but end up in the same boat.
    One other thing- I can't get the Computer Icon on the desktop. I can create a shortcut on the desktop, but that's not what I want. Usually there is an option to "Show on desktop", but that is not available. Anyway to fix that? Yeah, I know there is, but I don't know what it is- yet.
    Re-installing Windows 7 is not the way I want to go, knowing how it takes days to get all the updates again while the poor thing just sits there and runs and runs. I'd like to get this thing back to the lady as soon as I can, but I'm certainly not breaking any speed records with that task!
    I hope someone can come up with a cure for this Dell beast. It's the N7010 model.
    Thanks to anyone who can come up with the cure.
    Ron K
    First thought. Are you installing the correct driver from the Dell Downloads? Or a hardware driver from another location? Or has Windows installed the generic, basic function, High Definition Audio Driver (Codec)?
    If its not the Dell driver, that is the first step. However, with other problems I suspect the ultimate fix is going to be a "factory reinstall". Depending on the age of the PC there can be a Dell recovery partition, accessed by F8 at power on and that will restore it to the original factory condition. True it won't have all the updates but it will fix all the problems.
    Here is the link to the correct Dell Realtek sound driver
    Support for Inspiron 17 N7010 | Dell US
    While you are at the Dell downloads, also download and install the System Utilities/System Software Utility. That MAY help with some of the problems.
  3. Posts : 57
    Funny I didn't get a notice that anyone had replied like I usually do. Anyway, I saw a Rollup update and a couple security updates so I did them. After I rebooted the volume control was back and accessible. I had rebooted it several times before after fiddling with it, but the rollup update fixed it. All set! Thanks for your help!
  4. Posts : 57
    Look at that! I used 'before' and 'after' right next to each other in the same sentence. Funny, to me anyway.
  5. Posts : 8,135
    Great. Problem solved.
    I didn't think anything of the grammar usage. I'm a "Pennsylvania Duchman" originally from the Harrisburg area. LOL
  6. Posts : 57
    Harrisburg! We live in Williamsport. We lived in Harrisburg and New Cumberland a couple different times. We moved here from Harrisburg in Sept of 98.
  7. Posts : 191
    Windows 7 Home Premium bit
    Ha! Ha!
