Windows 7: Connecting the: Front-Audio-Panel-Header
20 Apr 2017   #1
mac1234
Windows 7 Pro x64
Re: Connecting the: Front-Audio-Panel-Header
My MotherBoard: Gigabit (GA-Z87-HD3 / rev: 1)
My PC Desktop case is: Antec Sonata III 500 case.
and its the version that has only these 4 connectors on its front, ie:
eg: 2 x usb + 1 x mic & 1 x line-in.
The case's Front-Audio-Panel-Header has an 10-pin plug labelled HDA (9pin plus one blocked)
The MoBo has a similar socket (F_Audio) which the MoBo-book & Antec-book says should be used for HDA.
However, the case-plug pin-diagram terminology,
doesn't seem to exactly match the terminology for the MoBo socket
(see the 2 tables in the attachment)
I would appreciate your advice:
So would you please translate the meaning of these terminologies.
Connecting the: Front-Audio-Panel-Header-hda_plug.jpg
20 Apr 2017   #2
fireberd
Looks compatible to me. The terminology is different for some but they both mean the same thing.
I've built a lot of desktop PC systems and never really looked at the exact connector terminology. If it had HD Audio marked on the connector and it had a matching audio connection on the motherboard I hooked them up and they always worked.
20 Apr 2017   #3
Layback Bear
Windows 10 Pro. 64/ version 1709
I do the same and have had no problems.
Jack
Using both front panel audio and back panel: solutions
This possibly should go in the hardware forum since it involves the motherboard as well but being a sound issue I assume here would be better. I have an Asus Xonar DG sound card on an Asus P7P55D-E LX motherboard (and AMD Radeon HD 7800 Series video card) running on Windows 7 Home Premium...
How to disable read audio panel and make the front panel primary?
Hello. I am having a not so common issue of a problematic REAR audio panel jack. The microphone pin got stuck and broken into the rear/back microphone jack and now the OS/driver thinks there is a microphone in the back panel but I just want to be able to make the microphone work on the front panel...
USB 3.0 Front Panel Header
I have a Corsair case with an Asus P8Z77 LX motherboard. I have already had Corsair send me a replacement front panel connection for the USB 3.0 ports, and am now stuck at what to do. Basically USB 2.0 connection speeds are abysmal over the front panel USB 3.0 ports. USB 3.0 (Hard disk and...
Hardware & Devices
Connecting "HD audio" cable from front panel to sound card
My sound card Xonar D1 doesn't work properly and i wrote to ASUS and they told me to connect the "HD audio" or "speaker" cables from the front panel of motherboard to the sound card's front panel. Is that safe to do? weather it will work or not, is it safe to try?
Connecting Front Panel Audio to Sound Card
I have a front audio panel and a CMI 8738-6ch sound card. The front audio does not work and has a wire coming directly from the back of it with this plug on the end of it... https://lh6.googleusercontent.com/-qn5Chte32nY/T3C78xg6Q9I/AAAAAAAAAIw/Kf0MPEnaTp8/s512/20120326_194826.jpg There are...
