Windows 7: Yet another problem; the audio system is often disabled after boot up
26 Jun 2017   #1
Syncopator
Windows 7 Home Premium 32bit
The 'speaker icon displays a red warning.
If I look in Device Manager, the High Definition Audio Device properties window says that it is working properly.
I have to disable it and then enable it. The red warning then disappears from the 'speaker icon.
26 Jun 2017   #2
ethel
Windows 10 Pro 64 bit
audio disabled
Hi Syncopator, Have you tried this
Click start orb
Click Control Panel
Click Hardware and Sound
Click Sound
Audio devices will come up, right click on the device you wish to set at default.
27 Jun 2017   #3
Syncopator
Quote   Quote: Originally Posted by ethel View Post
Click Sound
I don't have that anywhere on the computer. All I have, via Device Manager, is "Sound, video and game controllers", which has one entry, "High Definition Audio Device".
27 Jun 2017   #4
ethel
Hi Syncopator, The link below shows you from the start menu, where the control panel is to the right.
Start Menu All Programs in Windows 7 - Restore Default Shortcuts
27 Jun 2017   #5
Syncopator
This is what "Sound" shows me. It doesn't help me at all.
Yet another problem; the audio system is often disabled after boot up-sound.jpg
27 Jun 2017   #6
ethel
Hi Syncopator, Have you typed services.msc in the startmenu search box.
Check Multimedia Class Scheduler is set to Automatic Startup
Windows Audio Endpoint Builder is set to Automatic Startup
Plug and Play Automatic Startup
27 Jun 2017   #7
Syncopator
Yes, they're all set to automatic startup.
27 Jun 2017   #8
ethel
Hi Syncopator, I have been reading on HP's site and the audio driver it is showing for HP Compaq dc 7900
is ADI HD Audio Driver for Microsoft Windows 7. I just thought it was something else to look at.
https://support.hp.com/us-en/product/hp-compaq-dc7900-convertible
28 Jun 2017   #9
Syncopator
Thank you for that. Although my PC is a different model, HP Compaq dc7900 Small Form Factor (sic) PC,they both have the same audio driver.
I had searched for an updated driver via Device Manager but the system said that the best driver was already installed.
Nevertheless I have downloaded the one from HP's site. Let's see if that cures the problem.
04 Jul 2017   #10
Syncopator
After uninstalling Malwarebytes I got rid of this problem and sorted out another.
Audio Device is disabled! Help?
i have a problem with my laptop. it says, "No speakers or headphones are plugged in" and when i clicked it says, "Audio Device is disabled". I tried checking on control panel but it says there that speakers and headphones are enabled. see attachments.
5.1 audio system problem
Hi, first off all sorry for my bad english. A couple a days i've bought an audio card Asus Xonar DGX. I own a Logitech Z506 and my sound is not 5.1 . I hope u guys could help me...i installed the driver and my center and rear speker don't work. only 2 or 3 speakers work. Cheers
Audio problem, Audio device is disabled.
I turned on my laptop the other day and no audio would play from anything, like youtube videos or itunes. I checked my volume control nothing was muted. When I opened itunes I got a message saying "itunes has detected a problem with your audio configuration. Audio/video playback may not operate...
Audio device is disabled - no audio at all.
I'm on the verge of re-installing Windows. Spent the last 4 hours searching on here and other forums for a fix, but can't seem to find any. It started earlier today, I'd just installed Call of Duty: World at War off Steam, tried to launch it and it kept crashing. Tried a few things, but nothing...
Disabled Audio, how to fix?
Last night i was trying to get my USB headset to work and i accidentally disabled my sound cards audio. i was wondering what was the best way to recover the driver? (it does not show up in playback devices or device manager) and also how to do a system restore on windows 7? Thanks for any help...
