Windows 7: Speaker pairs with Bluetooth but no sound from speaker
28 Jun 2017   #1
Thira
Windows 7 Home 32 bit
Thanks in advance for any help.
I paired a UE 2 Boom speaker to an 2010 ASUS 1005 PC net book.
The speaker is paired, but streamed music is played by the netbook speakers, not the UE Boom Bluetooth speaker.
I have tried to update the Bluetooth drivers for the netbook, but it says I have the latest drivers.
Device manager says everything is working properly.
I uninstalled Bluetooth in device manager, rebooted the net book, and the Bluetooth reinstalled with the same results. Music from the netbook but not the Bluetooth speakers.
I have deleted the device in Bluetooth and paired it again successfully with the netbook, same results.
If I look in the sound, only the netbook speakers are shown.
The net book is running fine otherwise.
The netbook OS is Windows 7 Starter.
I would like to use the net book and speaker to stream Pandora and Shoutcast when in the garage, pool area, or working in the yard.
The netbook is small, long battery and streams music fine.
Plus I can leave my expensive laptop inside.
Thought about trying a Bluetooth dongle, but I am determined to get this going.
29 Jun 2017   #2
fireberd
Did you set the Bluetooth as the default audio playback device? If not, that is probably the problem.
Go to Control Panel/Hardware and Sound and finally the Sound panel, Playback section.
29 Jun 2017   #3
Thira
Thanks but not an available option
29 Jun 2017   #4
fireberd
The "Speakers" are the default playback device, unless you have an HDMI connection and then that becomes the default audio playback device. If the Bluetooth is not showing up as an option, its not fully installed or detected.
Check the Device Manager and see what it shows for the Bluetooth.
29 Jun 2017   #5
Thira
I had to connect the bluetooth speaker in the sounds to get it to show up.
Works perfect now.
Small and easy way to have bluetooth outside and in garage!
16 Jul 2017   #6
CaptainAutumn
ooh how did you do that??
Hi Thira
I'm having the same trouble , can you tell me how you got your speaker working?
Many thanks
Geoff
How do I make my laptop play sound through my bluetooth speaker?
Hi Folks I have been trying for weeks to get my thinkpad T420 to play through my new Anker Soundcore bluetooth speaker. I have already applied quite a few fixes from the web but still no joy. It kept trying to install a driver for it and failing, but Anker say it doesn't need a special driver....
Hardware & Devices
Win7 isn't discovering my bluetooth speaker?
Hi everyone, I recently had a few issues with bluetooth and chipset drivers after upgrading from vista home premium to win7 ultimate. The drivers installed correctly and I was able to pair with the speaker for a moment, though the sound quality was very bad, quite distorted and...
Hardware & Devices
Laptop not discovering bluetooth speaker
I am attempting to pair my Oontz Angle Plus bluetooth speaker to my laptop, but the laptop won't discover the device. I am able to pair easily with my cell phone (LG G3, Android) and my wife's laptop (Dell on Windows 8), but my laptop doesn't even see it. I have looked into the computer's bluetooth...
Hardware & Devices
USB Speaker & USB Bluetooth Adapter Not Working
hi there, my USB external speaker and USB bluetooth adapter (for my plantronics headset) is not working. I believe this had to do me removing a critical program (from add/remove programs) about half a year ago - i can no longer do a system recovery to retrieve the program. I'm currently...
Analog Speaker not detected. USB speaker works
Hi, I remember deleting something named "Realtek HD blah blah" from the below screen. https://www.sevenforums.com/attachment.php?attachmentid=219076&stc=1&d=1341120073 From then my normal speaker (audio jack) at the back doesn't work. But my USB speaker works. I tried to reinstall the...
