Windows 7: 1 second sound delay on playing audio or system sounds.
08 Jul 2017   #1
The Flume
I have recently been having this problem about this sound delay. I recently have replaced my broken AMD Radeon HD7700 to an NVIDIA GeForce GTX 750 TI Superclocked and my soundcard is built into the gpu I think.
I know this for BSOD's but here is the diagnostics file if you need it.
PS: I have been looking online for this problem but i cant find anything that works or even sloved.
08 Jul 2017   #2
fireberd
If you are using HDMI audio then the video card is supplying the audio. However, if you are using the standard motherboard sound and speakers then its the sound chip on the motherboard (or separate audio card) that is supplying the audio.
The XPS 8500 uses Realtek for integrated on motherboard audio.
The dump doesn't detail exactly which you are using. However, if you are using HDMI audio make sure you have the latest drivers for the video card.
11 Jul 2017   #3
The Flume
The problem fixed itself
the problem went after a few days its fine now
Sound crackling, clicking etc. when playing sounds
Hello there, I just got myself registered and I have some problems with my sound which now exist for ~ 6 months. 1. Problem: You could describe the problem as a sound clicking or crackling. Those appear in various situations, for example when playing a MP3, videos from YT, gamesounds and so...
PC sound problems. No system sounds, no audio.
Dell Studio XPS 8100 Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz (4 CPUs), ~2.7GHz 6 GIGs of RAM Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 I here as a last resort before formatting my hard drive. A couple of weeks ago the sound on my PC up and died, for no apparent reason....
Sound card sounds no better than integrated motherboard audio?
I purchased the Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card, a cheap, $30 card, and was expecting some improvement over my computer's integrated motherboard audio (Dell XPS 420), but I can't really tell the difference between the two. Is it possible for the...
Recording Audio/ mic and system sounds...with headphones?
I have a screen recorder that records my screen and also my mic at the same time, i make videos to help with my knowledge base articles in sharepoint. I need to record my mic/ and also system sounds like if i have someone on skype and i am screen recording, i need to be able to record there audio,...
Laptop will play system sounds but no other audio!
Hi, I recently upgraded to windows 7 (from vista) on my HP Pavillion dv9000 series (specifically dv9850ea) Beforehand when I ran the upgrade advisor, I got a few warning about incompatabilities - the graphics card for example - but all seems fine after the upgrade. My problem is with the...
