Windows 7: Why is my sound low / Crackling whilst sounding low
09 Jul 2017   #1
TechSeven
Hi
I switched on my desktop and turned on some music, at first i thought my volume was low.
So i turned it up and it still sounded low. It was also crackling.
So i uninstalled the audio driver and re installed it but no luck.
Ive tried different headphones.
But i think the problem is in the sound port maybe.
Not to sure yet
Any ideas pls?
09 Jul 2017   #2
TechSeven
I've just read ... Recently there have been numerous issues with abnormal audio issues on the new MSi models.
If your MSi has stacic, crackling, or distorted sound issues. | NotebookReview
sound crackling
sound cracking when starting windows or shutting down windows...sound does not crackle after windows has started...i am using an external usb sound adapter...when i use the built in realtek sound it hums...i am wondering if it is the video card or power supply
Crackling and distorted sound in Win 7
Hi all, A couple of weeks ago I bought and downloaded a copy of the "AOS system optimizer" and after using it to 'optimize' my system it instead screwed it up big time... now my sound crackles and stutters when I play all media, online or offline, dvds, youtube, games, etc... Technical...
Genius Sound Maker Value 5.1 Crackling Sound
Hello, I upgraded my Win XP to Win 7 like 1 month ago. Downloaded all drivers (from their sites) updated them... then i open WMP 11 and start playing some music. After listening to that i heard some weird sound lag, I believe its called crackling. I searched on internet found some solutions, but...
[Sound crackling ] VPN client messed up my sound settings
Hi folks, Recently I was setting up a VPN client (PacketIX), and the setup wizard suggested some Audio/Video Streaming "Optimization" tweaks. I didn't pay attention and confirmed. Since then, I often hear some crackling / popping noises. For instance, this systematically occurs when I...
Crackling Sound
Hi all, Am new to the forums so please be patient with me! :D My machine is fairly old but runs Windows 7 32Bit perfectly fine. In fact I was amazed to find all the hardware is picked up fine and runs nearly as fast as XP did. Have been using it for some time without issues but recently...
