Windows 7: Sound from some programs, no sound from others
13 Jul 2017   #11
fireberd
I see an MP3 decoder, but it may be specifically for one program. I would install the K-Lite Codec pack and see if that fixes it. It won't hurt. I used to use that when I had Vista and Win 7.
13 Jul 2017   #12
perkinw
I disabled AMD, but no change in results.
I downloaded the latest driver by following the link you sent. It is version 6.0.1.8199 dated 6/27/2017. My current RealTek driver is version 6.0.1.7560 dated 7/15/2015. I extracted the contents of the cab file into a folder. I used the Update Driver... button in the Realtek driver properties to browse to the folder. But hen I clicked Next, Windows gave me the message below.
13 Jul 2017   #13
fireberd
IMHO I don't think the sound drivers have anything to do with the problem. It has to be more a specific problem such as a missing codec.. The sound works fine with other applications.
13 Jul 2017   #14
perkinw
I installed the K-Lite codec pack. Still no sound from WMP, and still the error message. Interestingly, the codecs displayed by WMP show NO CHANGES whatsoever after installing the codec pack! All versions and dates are the same as before.
What continues to bother me is that in WMP, Speaker Properties shows an empty menu for audio devices. I would expect to see Realtek in the menu.
Sound from some programs, no sound from others-audio-video-codecs-wmp-after-installing-k-lite-codec-pack.jpg
13 Jul 2017   #15
perkinw
I found someone else with the identical problem to mine here. The discussion went on for many posts, but no solution was found.
I ran dxdiag.exe. It says "No sound card was found." That probably explains the empty audio device menu.
Sound from some programs, no sound from others-dxdiag-no-sound-card-found.jpg
13 Jul 2017   #16
fireberd
"Refresh" the Realtek. Go to the Device Manager. RIGHT click on the entry for the RealTek and then LEFT click "Uninstall". DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound. This is one of my "stock fixes" as this corrects any corruptions between Windows and the sound, and many flakey problems. If you are lucky it will fix yours.
13 Jul 2017   #17
perkinw
I'm confused because the context menu for Uninstall says it will uninstall the drivers!
Sound from some programs, no sound from others-uninstall-realtek-high-definition-audio.jpg
13 Jul 2017   #18
rvcjew
7 Pro x64, 10 Pro x64
On phone sorry for crappy formatting , after you hit uninstall it will have a separate check box for drivers, do not check it. Then hit okay and reboot.
13 Jul 2017   #19
perkinw
I refreshed the Realtek as you instructed. After restart, I saw "installing device driver software." Problem in Windows Media Player persists. WMP still does not see an audio device. Dxdiag.exe reports "No sound card was found." The problem seems unique to WMP, since I can play mp3's in VLC and iTunes. And I get all system sounds, sounds in browser (YouTube, etc.). Nothing has changed since refreshing Realtek.
13 Jul 2017   #20
perkinw
What about uninstalling Realtek (with "delete the driver software for this device" checked) and then reinstalling the driver from the manufacturer's web site? Earlier I tried doing an "update driver" but Windows told me the driver was already up-to-date.
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound only works for some programs
Hello, I am having issues with my sound. My sound was working fine, then one time after starting it up I noticed the sound on youtube wasnt working, I then found out this was only on youtube, on Google chrome only. Then I found out that half my games sound wasnt working, but others work fine. After...
programs sound unmutes itself
I am trying to record music from spotify to download onto Windows Media Player and I am on facebook talking to somebody and to turn off the sound when somebody messages me I go and mute internet explorer and when I close the mixer, internet explorer unmutes itself, is there a way to where I can fix...
Some programs' sound not detected!
Currently, I have a few games running, but their sounds are not detected by the speakers/headphone playback devices. how can i make it so that my computer can detect the programs? because none of the devices have the program's audios in them? the second thumbnail shows other programs working...
No sound from audio programs?
I have a new windows 7 x64 PC, using an M-Audio Delta 1010LT sound card. I can get system sounds. When I try to open an audio program, such as EastWest virtual instruments or Cubase 5, I get no audio output. My settings appear to be correct within these programs. Any suggestions on how to fix...
