Windows 7: Sound from some programs, no sound from others
13 Jul 2017   #21
rvcjew
7 Pro x64, 10 Pro x64
Yeah that is odd, uninstall it with the the box checked then reboot without your internet connected so windows does not try to get its own drivers. Then install that June version, connect to the net and reboot.
13 Jul 2017   #22
perkinw
I will do that in the morning. Even if it doesn't solve the problem, I really appreciate all your help!
14 Jul 2017   #23
fireberd
I think we are down to a Windows OS problem rather than just the sound, since DXDiag does not detect a sound card.
I don't think SFC /Scannow will fix it either. Sadly, I'm of the opinion a full reinstall will be needed.
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound only works for some programs
Hello, I am having issues with my sound. My sound was working fine, then one time after starting it up I noticed the sound on youtube wasnt working, I then found out this was only on youtube, on Google chrome only. Then I found out that half my games sound wasnt working, but others work fine. After...
programs sound unmutes itself
I am trying to record music from spotify to download onto Windows Media Player and I am on facebook talking to somebody and to turn off the sound when somebody messages me I go and mute internet explorer and when I close the mixer, internet explorer unmutes itself, is there a way to where I can fix...
Some programs' sound not detected!
Currently, I have a few games running, but their sounds are not detected by the speakers/headphone playback devices. how can i make it so that my computer can detect the programs? because none of the devices have the program's audios in them? the second thumbnail shows other programs working...
No sound from audio programs?
I have a new windows 7 x64 PC, using an M-Audio Delta 1010LT sound card. I can get system sounds. When I try to open an audio program, such as EastWest virtual instruments or Cubase 5, I get no audio output. My settings appear to be correct within these programs. Any suggestions on how to fix...
