Windows 7: Sound from some programs, no sound from others
10 Jul 2017   #1
perkinw
I have speakers attached to the 3.5mm jack on the rear panel of my PC. No other sound devices are attached.
[EDIT: I can't figure out how to get google photos links to display inline]
In Device Manager, I see two sound cards:
In Control Panel -> Sound I see this:
The properties for the "not plugged in" devices all give Jack Information as "HDMI Digital Jack." Nothing is plugged into the HDMI jack.
Here's the problem:
If I play an mp3 file in Windows Media player, there's no sound. I get an error message:
If I try to play the same mp3 in VLC, there's no sound.
I get sound in from the following: iTunes, audio and video in the browser, and all system sounds.
Is the problem that VLC and Windows Media Player are somehow trying to send sound to the AMD audio? If so, how do I tell them to use Realtek audio so I get sound from the speakers?
Sound from some programs, no sound from others-device-manager-sound.jpg Sound from some programs, no sound from others-sound.jpg Sound from some programs, no sound from others-windows-media-player-error.jpg
12 Jul 2017   #2
rvcjew
7 Pro x64, 10 Pro x64
Windows media player should be using the one selected in windows. For VLC though go to tools/preferences and pick audio then Wave out and select the device you want. For WMP hit alt then tools/options and under devices go to the properties of speakers and pick your device.
Sound from some programs, no sound from others-sound.png   Sound from some programs, no sound from others-sound-2.png
12 Jul 2017   #3
perkinw
Your solution solved my problem with VLC. Thanks! However in WMP, the "Select the audio device" menu in Speaker Properties is empty.
12 Jul 2017   #4
fireberd
"Normally" the Default "Recording" device is set to Stereo Mix (could be labeled System Mixer on some older systems), or if you are using Creative SoundBlaster they call it "What You Hear". Most programs will default to that with options for other recording sources.
"Speakers" (PC sound card) should be set as default Playback Device.
In Device Manager, if you have a video card with an HDMI option, you will see the entry for the HDMI Audio and also one entry for the PC sound card driver, such as Realtek, Conexant, etc. If you only see "High Definition Audio" that is the generic, basic function, Windows installed sound driver and if that is the case you need to install the correct hardware sound driver (which may fix your problems).
Here is my Control Panel/Hardware and Sound/Sound Panel, Recording Tab section, which is common on many systems.
12 Jul 2017   #5
perkinw
Hi Fireberd, thanks for replying. In my OP I included screenshots of the Device Manager and Sound. I do have two drivers in Device Manager (AMD and Realtek) exactly as you described. In Sound, the Playback tab shows Speakers / Heaphones (Realtek) is enabled and the default and the Digital Display Audio (AMD) is not plugged in. But I do not get sound from Windows Media player.
FYI I am not recording, only trying play back sound. But just to be safe, I set my Recording device to Stereo Mix as you did.
12 Jul 2017   #6
fireberd
Stereo Mix is used as the default audio source for many programs. Its basically "what you are hearing on the speakers". Its sort of a misnomer to call it a "Recording" device. If you wanted to record audio from the Internet, you must have Stereo Mix and that is the source for recording.
On my WMP (I have Win 10) there is a speaker icon to the right of the Play button, and you can mute and also control volume. Check that its not muted and that the volume is not at "off".
12 Jul 2017   #7
perkinw
Muting or volume is not the problem. When I try to play an mp3 in WMP, I get the attached "There is a problem with your sound device" error message. Could the problem be that "the sound device is in use by another program?"
12 Jul 2017   #8
fireberd
You apparently do not have the codec to play MP3's. There are codec packs that can be downloaded.
KLite codec pack is one that is popular.
K-Lite Codec Pack 13.3.3 Free Download
12 Jul 2017   #9
perkinw
Hi fireberd, These are the codecs which are reported by Windows Media Player. Am I missing one that I need? Or should I just go ahead and install KLite codec pack (assuming it won't interfere with any of the codecs already installed ). In my original post, I mentioned that I can play mp3's in iTunes. I can also play them in VLC after I made your fix. WMP is the only program still not able to play mp3's. Thanks.
Sound from some programs, no sound from others-audio-video-codecs-microsoft-media-player-.jpg
13 Jul 2017   #10
rvcjew
The AMD sound device is the digital audio of your GPU, if you don't want that conflicting if your not using audio over HDMI then I suggest you disable that sound device in device manager leaving just the realtek one then install the newest driver by extracting the cab file you download from the section front page for realtek on windows 7.
Latest Realtek HD Audio Driver Version - Windows 7 Help Forums (June 27th one)
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound only works for some programs
Hello, I am having issues with my sound. My sound was working fine, then one time after starting it up I noticed the sound on youtube wasnt working, I then found out this was only on youtube, on Google chrome only. Then I found out that half my games sound wasnt working, but others work fine. After...
programs sound unmutes itself
I am trying to record music from spotify to download onto Windows Media Player and I am on facebook talking to somebody and to turn off the sound when somebody messages me I go and mute internet explorer and when I close the mixer, internet explorer unmutes itself, is there a way to where I can fix...
Some programs' sound not detected!
Currently, I have a few games running, but their sounds are not detected by the speakers/headphone playback devices. how can i make it so that my computer can detect the programs? because none of the devices have the program's audios in them? the second thumbnail shows other programs working...
No sound from audio programs?
I have a new windows 7 x64 PC, using an M-Audio Delta 1010LT sound card. I can get system sounds. When I try to open an audio program, such as EastWest virtual instruments or Cubase 5, I get no audio output. My settings appear to be correct within these programs. Any suggestions on how to fix...
