Windows 7: Need ideas on external pci sound card please
13 Jul 2017   #1
TechSeven
hi
im thinking of buying a pci external sound card
but it must be AS GOOD as the onboard audio on this motherboard or BETTER
the audio on this motherboard was awesome ... but something happened and the audio does produce the right sound
26 Jul 2017   #2
ICIT2LOL
Hello mate now why an external sund card have yu go no slot left??
Personally I use Asus Xonar cards in my desktops two with the older DG model and one with the current DSX.
Both have a brilliant GUI for mixing / effects / speaker positioning etc
You can see in the pic in the link it does not need a huge slot either and gets power from the board it can drive up to 7:1 systems my current Logitec Z506 (5:1) almost rips the room apart LOL!!
Xonar DSX | Sound Cards | ASUS Australia
26 Jul 2017   #3
fireberd
What is the issue with the on-board sound? Maybe it can be corrected?
Switching between onboard sound and external sound card
First, let me say that I am a sound novice! I recently started a vinyl ripping project. My onboard sound does not support 24 bit depth recording at 96 kHz sampling rate, so I purchased an external USB card with phono preamp. It works just fine for my project. But as long as external sound card...
Realtek network card not working with external sound card installed
Hi all, I recently bought a relatively expensive sound card on Amazon and after the second boot of my PC with the card installed and working my on board LAN card decided to not work throwing error: "This device cannot start. (Code 10)" The card IS enabled in the BIOS and I HAVE disabled the...
Hardware & Devices
Using an External Sound card
Hello all, as my internal laptop sound card doesn't support SPDIF out - i've decided to go with an external sound card and through the external sound card - hook it to my receiver for 5.1/7.1 sound. My question is how is it that i would connect my external sound card to my receiver. Say i was to...
Need external sound card
I have an Alienware Area-51 7500-R4 with intergrated Nvidia C-55-MB. I recently installed Windows 7 (Custom, clean installation) and I only have sound on my two front speakers, no center or rear speakers. Alienware support is unable to help and I was told I could not install an internal soundcard...
Looking to buy a new external/usb sound card
Hello 7forums, My onboard soundcard isn't working with win7. I really like the performance win7 is giving me for everything, from games (no sound), to processor-heavy loads, but I just can't get the audio to work. I have tried a lot of sound drivers listed in these forums, but they all say the...
