Mic won't produce sound
  1. Posts : 1
    Win 7 64bit
    Hi there.
    I'm trying to get my microphone to work properly with Windows 7 64Bit. I have the latest audio drivers found in the sticky on the forum. All my other drivers are fully up to date and functioning correctly.
    When I plug my mic in (back or front) windows recognizes that I've done so. The mute switch on my cord is OFF. I can see the microphone in the sound settings, and I can get it to display a few green bars by changing certain settings.
    I don't have skype or any other voice applications installed as of yet. I have been doing all testing with "record sound" and setting my headphones to hear the sound.
    The only thing I can't do is get my voice to work in any applications.
    It is very unlikely that my mic is broken, it worked a few weeks ago and since then it has just been detached inside a drawer while I wasn't using it.
    Any suggestions would be great, I'm currently in pursuit of another headset to test for hardware issues.
    Thanks.
  2. Posts : 4
    I am having the same issue
    I also am unable to have windows recognize my mic. I can hear myself when I test it in the sound properties:
    Control Panel\All Control Panel Items\Sound > Recording Tab > Microphone > Properties > Listen
    I am able to hear myself, so my mic works fine.
    However, when I try to use my mic in Skype or Steam Voice Chat, nothing comes through.
    Specs:
    OS: Windows 7 Pro x64
    CPU: Core i7 920
    GPU: EVGA GTX 280 SSC
    Memory: 6 GB DDR3
  3. Posts : 8,135
    Does the mic work with the Windows "Sound Recorder" ? If it will work with the Sound Recorder that usually indicates it's working correctly.
  4. Posts : 4
    Possible Solution
    Open Skype then go into the settings > audio. Unplug the mic from your computer and plug it back in.
    It is very important that Skype be running.
    Hopefully this works for others too.
