Windows 7: Realtek Audio volume slider bar won't increase volume. No sound at al
27 Jul 2017   #1
mtcspurgeon
Windows 7 64 bit
I recently lost all sound on my desktop computer. I have done troubleshooting and it indicates my Realtek Audio is working. It also said it detected low volume and fixed it. However, still no sound. I try to slide the volume bar to 100% but it automatically slides back to 0%. I have updated the driver and it indicates that all is good. Still no sound. I rebooted my computer. Still no sound. I've checked the speakers and connections. Still no sound. I'm getting frustrated. Can anybody help me?
27 Jul 2017   #2
mrjimphelps
Linux Mint 18.2 xfce 64-bit (VMWare host) / Windows 8.1 Pro 32-bit (VMWare guest)
Try plugging your speakers into something else, such as a new computer, a phone, etc, to see if they work there.
Do you have two speaker jacks on your computer? If so, try plugging your speakers into the other speaker jack. For example, there may be one on the front and one on the back of the computer.
If you don't get any further by following the above steps, try logging into Windows as a different user, to see if that solves it.
27 Jul 2017   #3
mtcspurgeon
Windows 7 64 bit
I checked the speakers, changed speaker jacks and logging in as different user did not work. The volume slider bar just keeps slipping back to 0%, no matter what I do.
audio can't be changed even when i change the volume slider
hi, my comp is having some audio problems and i need help. -windows 7 ultimate 32 bit- my audio didn't work even when i change the volume slider no sound is coming from both speakers and headset i tried to restart/shut down my laptop but it wasn't work i don't know what to do.
Software to increase system-wide audio volume in Windows 7?
Hi all, I currently have a VirtualBox VM (virtual machine) of Windows 7 Professional running on a host Windows 7 Ultimate, both 64-bit. I am in a situation where I am finding the audio output from my VM is simply too low in volume even with the VM Windows's volume set to maximum at 100%. While a...
Volume Control wont move sound card slider
I have E-MU 1212M sound card, Windows 7 and I can't fix this problem which I haven't had before. I reinstalled the Windows 7 and now I can't move my Volume Control and affect my sound card volume. My sound card volume wont move until I move it. It's like my volume mixer is pre-effected,before my...
How to increase max volume and decrease minimum volume
I use W7's volume control for the studio monitors I use. It's not practical to use the knob on the monitors since it is located in the back. The max volume (100%) in W7 is not loud enough while the minimum volume (0%) still makes sound when Id like it to be mute if it's at 0% How can this be...
Show sound slider when adjusting volume?
I used to have a volume bar in XP, but those drivers no longer work. I have no visual indicator of system volume. That's significant when viewing online media because the system may be maxed out, while the media player may not. I'd absolutely love the Win7 sound slider to show up when I turn...
